    boost-addict's Avatar
    Aug 2011
    977
    Cause and solutions to v6 tdi revving to 3k
    Looking to buy a tdi. I like the 2.5 and found one that has two faults.
    First is it runs out of fuel at 1/4 tank which after some searching turnt iut the transfer pump could have packed up.
    Second is it stops reving at 3k
    No mention of if it revs at idle.
    Ive found so far
    Blocked cat can be the main factor
    Air in fuel line from t-peice
    Turbo vanes stuck
    Altitude/boost sensor faulty
    Is there any thing else
    And can it be fixed? I presume this a common problem on vag tdi engines?
    Im tempted by the lower price but dont want to be stuck sticking money in to something i may eventually not solve
    The seller says he dosnt want to take it to a garage in fear of a big bill. Altho id say he must know as even i would go to a garage or seek help in the dirst instance of me not finding a fault like vanes or a blocked cat.
    So what can i ask the seller to give me a better understanding. And if he has no clue can a problem like this become a costly one
    Jan 2011
    Aberdeenshire
    628
    You need to scan it.
    Most likely it will be an overboost, then it goes into limp mode.
    There are quite a few posts on this have a search on here but
    the faults you listed are the main ones.
    Try checking the turbo actuator is down with the engine off, then watch it when the engine starts. It should move up to the stop freely.
    If it doesn't move, check the boost hoses and the N75.
    If it does move, try moving it by hand and feel if it is sticky or rough. If it is, buy your can of mr muscle.
    You can see if air is getting in by looking at the clear fuel line and watching for bubbles - rev it a bit whilst looking
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Aug 2011
    977
    I have serched! And thats the info i found. So theres not anything else other then mentioned that can cause this fault?
    Jan 2011
    Aberdeenshire
    628
    On any electronic vehicle, any of the ECUs involved in fuel or propulsion can cause strange faults too.
    However, the faults listed above seem to be most likely - but you must scan for fault codes first.
    To try and second guess which of the aforementioned faults you have without seeing what the ECU has logged is a path to unnecessary time wasting and expense.
    Jan 2011
    Aberdeenshire
    628
    On the plus side, once you get a 2.5 (Q?) running well you will enjoy yourself!
    I average (over a couple of years) 40+ MPG on my 2.5TDI Quattro saloon and it also goes like stink when I want it to.
    Aug 2011
    977
    yer might see if hes price will come down, wants £600 currently
  1. Telling the difference between the 140 and 170 2.0 TDI
    By Bugsy_27 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2012, 23:26
  2. Rear discs and pads. 2.0 TDI 140 (2003)
    By xs2man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2010, 10:53
  3. What bulbs are in the front of my car? and the Numberplate? 04 TDi S-Line
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2010, 18:20
  4. Hot and Cold Heater A4 tdi.
    By chris a4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st December 2009, 14:14
  5. The Causes and Dangers of Pinking!
    By Administrators in forum General Technical / How To
    Last Post: 20th February 2003, 19:19
