EM TuningMonster Motorsport
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: A4 quattro rear noise driving me crazy!
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    255
    Coming up for 150k on my 2001 A4 2.5 TDI quattro sport avant (AKN engine). Since Easter there had been a rumble noise from the rear that increases with speed. So far I've replaced the rear wheel bearing (passenger side), checked rear diff fluid level which is fine, fitted two new rear tyres, and have just fitted Brembo discs and pads all round. Two different garages thought it could be the rear discs or rear wheels as they were due for replacement.
    When I replaced the rear discs (passenger side) I noticed there was a little grease weep on the outer CV joint (steel band). I replaced the reluctor ring on this drive shaft a couple of years ago. The rubber boot is not torn. Got me thinking that this joint could be either running dry or is simply worn out.
    Are rear outer CV joints worth re-packing, or just replace it? The Ebay part looks like £30, and I'm tempted, but would rather go for OE quality, but the mounting cost of replacement parts is driving me nuts. Is it worth re-packing the joint first?
    Any suggestions?
    2010 Škoda Fabia 1.6 TDI CR (105) Elegance (31k)
    2002 A2 1.4 TDI SE (130k)
    2001 A4 2.5 TDi Avant Quattro Sport, aka Amrak Locomotive (162k)
    1995 80 TDI Avant SE (175k) Sold
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Id be replacing the O/S/R wheel bearing !!
    mine had a rumble wa wa wa noise which sounded as though it was the N/S/R as there was play in the bearing replaced it and was still there and still sounded like the N/S/R so did the other side and its fine now !!
    Message seller:stephanj65 on ebay he got my front febi CV boots and they were good quality boots with heavy duty clamps snd next day delivery for £36, he may be able to get rear cv joint kits with boots if you get the oem part number he will have a look for you and come back with a price !!
    thats only if the wheel bearing doesnt cure it !!!!
    PAULF likes this.
    Dec 2008
    Aberdeenshire
    255
    Quote Originally Posted by Bradderz_1988 View Post
    Id be replacing the O/S/R wheel bearing!
    Cheers Bradderz. I'm still convinced its a cv joint. I know what a bad bearing sounds like, and the sound isn't there from start-up. We'd gone 25 miles into town, quiet as a mouse, and it was only on the return journey it started. My experience of bad bearings is they hum at 40-50mph from start-up.
    I'll contact the seller you mention to see what he as.
    Feb 2012
    92
    I had the same thing when a rear bearing was going, it would be quiet at start of the journey, then after a few miles it would start making noise, there wasn't any significant play in it either to start with, just noise.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    Change the bearing. You should have done both when you did the one you've already changed.
    TD5 Land Rover Defender build
    Aug 2011
    199
    +1 on the bearing(s) - I had a front one go and there was no evident play, no roughness, nothing, just noise! Changed bearing - noise gone. Mike.
    Dec 2008
    Aberdeenshire
    255
    Thanks for all the feedback. I hear you regards the other bearing.
    It's all money just now. Thinking of becoming a MP. Seems they can get £10k pay rise... even although we're all in this together! Aye, that will be right! Keep you posted! Rant over!
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Did this turn out to be the CV joint?
    spartacus68's Avatar
    Jan 2012
    Aberdeenshire
    56
    Quote Originally Posted by Iceash View Post
    No its the bearing. Garage that fitted it are replacing it again tomorrow free-of-charge.
    Is that with or without VAT?
    2001 B5 A4 2.5 TDI Avant quattro sport (155k)
    2003 A2 1.4 TDI SE (125k)
    1995 80 TDI SE Avant (175k) sold
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    That's good. Mine is also rear near side bearing. Just waiting for a price. What did you pay btw?
    Jan 2012
    Aberdeenshire
    56
    £250 to fit bearing, however that's not including the further three times (to original VAG specialist then my own local garage) to diagnose and confirm fault after fitting, that was another £150!
    "Stick a V8 in it!"
    15,385
    Yikes!
    Aug 2010
    3,138
    My bearings cost me £50 for the pair fitted by myself !!
    Jun 2013
    Montrose, Tayside
    89
    I was £18 for both rears fitted by myself on my old 2.8Q
    that was 3 years ago though
    I need to do the rears on the current one actually
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    So 250 too much?
    Aug 2010
    3,138
    Yeah way to much if you dont have access to a press id personally be talking the uprights off, buy 2 skf bearings for around £50 then take them to your local garage and ask them to press them in for you, and pay an hours labour tops !!!
    and also give them a good clean up and a brush over with black hammerite or similar just whilst there off and so there not all grubby looking !!
    boost-addict's Avatar
    Aug 2011
    977
    going to ask a quick qestion here as kinda have a simler problem
    i had the bearing noise replaced with good struts/bearings and now at very low speeds i have a rubbing noise, i broke the sensor getting it out but was able to get the tab to hold the sensor. it only happens in netrel and at low speeds. the bearing humming noise has gone but now got another noise, the rubbing sound which is on and off increases with speed but then stops. maybe ive got some thing rubbing some were? or maybe the sensor is to far in the housing? i have a symbol thats come up aswell.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Think I'll be handing over to my trusty mechanic lol
    hammerite idea I like though.
    Aug 2011
    977
    yer its always good idea to hamerite stuff, even brand new stuff like arms, as the coating is thin and eventually falls off and rusts which looks mucky
  1. Audi A4 quattro noise driving me nuts!
    By spartacus 68 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2013, 14:18
  2. S3,TT,A3 quattro rear drive shaft set
    By boostjunkie in forum For Sale/Wanted - Audi Parts
    Last Post: 4th May 2013, 09:11
  3. A3 Quattro rear drive shaft
    By Dan_Sykes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2012, 07:31
  4. 1999 AUDI A4 2.8 QUATTRO REAR NOISE
    By ROUTY in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th September 2009, 14:32
  5. Quattro Rear Vibration Noise...
    By faaaaast in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2008, 09:36
