Sky InsuranceBadger5
Results 1 to 8 of 8
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    face lift wings fir pre facelift?
    will facelift wings fit onto a pfl?
    my wings are rust free but I fancy getting the smother look
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I think they are direct fit yes id wait for the experts on this to come along, Do you need any facelift headlights will have a set in a week or two if interested ill PM you some info ??
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Pretty sure they just swap out. I await correction though.
    Life begins at 140mph
    www.passionford.com
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    My thinking as well.
    Same but the headlights needs swapping and the indicators.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Aug 2010
    3,138
    My S4/RS4 xenon lights should be here beginning of the week so ill post pics up on here if your interested in the lights !! They have bungs in the access caps due to having HID's fitted and also the drivers bottom lug is broken but can easily be repaired using one of your old o/s headlight if your any good at diy stuff, i also hsve a set of PFL S4 ballasts and some H7 to D2S/D2R adapters if you wanted to convert them to Xenons using the proper D2S/D2R bulbs (havent tested the ballasts but will do if interested).
    jbh
    jbh's Avatar
    TDi lover
    704
    Quote Originally Posted by Bradderz_1988 View Post
    cheers bud my car already has the facelift headlights and bumper it had them when I bought it which was a bonus
    any more info on these? pm me
    Aug 2010
    3,138
    The ballast are all complete with wiring they will just need the feed and earth wires modifying with some spade connectors to take a feed from your H7 bulb connector or just cut off connector and solder wires together, ive looked over this and you could even make a bracket to mount them on the recess under the lights these are bulky hella ones not the flat valeo type that the facelifts have so arent a perfect fit and there will also be room to feed the wires in underneath the lights which will be a neater job overall !!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    The wings physically fit, but the door trims are different, much wider on the FL cars.
    You'd probably want to peel the trim off and fit a PFL one so it matched.
    TD5 Land Rover Defender build
  1. Pre face lift s3 xenons to facelift s3 xenons..
    By donjon in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2011, 17:06
  2. pre facelift coilovers on a face lift car?
    By SteVR in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd July 2010, 07:14
  3. A3 pre-face lift. A3 facelift.
    By Ravi A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2010, 10:35
  4. pre-face lift wing mirrors
    By Madmatt in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2009, 14:34
  5. Pre-facelift ally Mirror conversion to face-lift
    By in forum General Technical / How To
    Last Post: 29th June 2005, 22:29
