Badger5Sky Insurance
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By alinghi9
Thread: Auto gearbox not changing smoothly
    Feb 2009
    66
    Hi
    Have a '97 1.8 Auto, the gear change on the gearbox is not smooth at all, there are moments where it feels like the gears are "clunking" in to place. Usually happens between 2nd and 3rd and depending on the speed 3rd and 4th.
    Sometimes when driving and applying a bit more speed to the pedal, the car will rev up to 5-6K and you would some how expect a change of gear but nothing happens or it is very delays an unexpected.
    Would anyone know what the possible problem could be? is mechanical where by the gearbox is failing or is it more ECU type related?
    Any ideas on this would be great.
    Thanks!
    A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, 18 inch RS6, Eibach Pro Kit, Koni FSD.
    Jun 2011
    Great Melton Norfolk
    1,346
    Get the fluid changed, do the revs seem to flare when you accelerate? could be the clutch packs burnt out due to low fluid.
    Feb 2009
    66
    should have mentioned earlier, that the gearbox oil was changed out, but its still not a smooth transition through gears.
    Gen - when you say flare how you do mean exactly?
    Jun 2011
    1,346
    when you accelerate do the revs rise with no increase in speed. If it is banging into gears could be solenoids wearing out.do you know the exact model of the box?
    Feb 2009
    66
    right with you, no it accelerates fine as in when goes through the rev range there is no loss of power. I would say the only time there is and very occasionally is from a stand start there is no immediate power delivery.
    unfortunately do not know the exact model, any way for me to find out?
    Jun 2011
    1,346
    Sounds more like Solenoids. Gearbox code may be in/near spare wheel well on a sticker with all the engine code colour etc.
    Feb 2009
    66
    ok if not that do you think it could be anything else like the control unit?
    Jun 2011
    1,346
    Could be ECM for Box or Loom going to it.
    Have you had the car /gearbox scanned with VCDS?
    Jun 2011
    1,346
    Is the box 4spd or 5spd Tiptronic?
    Feb 2009
    66
    its a 4spd gearbox
    gen.heinz guderian likes this.
  1. 1998 A3 8l Auto gearbox change to neutral with it self??! help
    By aalsawad in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2013, 12:39
  2. auto gearbox oil change on 3.0 tdi quattro
    By .Jas. in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th June 2012, 14:11
  3. C6 avant auto gearbox oil change
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th May 2011, 22:03
  4. Auto gearbox new oil or not ?
    By H2o-uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2009, 09:43
  5. Auto Gearbox oil change at 70K ? / DIY methods
    By RogerTDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd October 2006, 08:54
