Results 1 to 11 of 11
    Mar 2012
    41
    N75 knowledge needed
    I wondered if someone can give me any advice on this. They aren't a valves I'm really knowledgeable about but I've been told if you fit the correct one gains can be found.
    I've just been offered a ECS N75 Race Valve and wondered if they are worth the swap. I currently have the later variant which I think is an E. Prior to this I think I had the F variant but this was shot hence the change to the later spec one.
    Thoughts and opinions please guys.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Stick with a standard N75 and get the car mapped with maybe some upgrades (injectors,maf,fmic etc) to achieve a proper gain !! Any other n75 just brings the boost in to harsh and doesnt show any significant gains overall !!
    Mar 2012
    41
    What injectors do people tend to go with and what is the MAF upgrade? May consider a change of plan. ;-)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    those components need matched to the turbo you've chosen and power level your aiming for.
    TD5 Land Rover Defender build
    Mar 2012
    41
    I'm thinking of heading down the ko3s route and aiming for about 230-250bhp. Really trying to get together a shopping list of bits I'd need.
    "Stick a V8 in it!"
    15,372
    K03s on an A4 doesnt really exist.
    What car do you have? Year? Engine?
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,642
    I suppose you have the K03-073 from the B6 BEX lump, could be classed as a K03's'
    Currently rolling in a SKODA!!!
    Mar 2012
    41
    It is a 98 AEB. Was advised I have a KO3 and that a KO3s would be a nice easy straight fit. :-/
    "Stick a V8 in it!"
    15,372
    Yeh, the problem is that the "K03s" isnt really that common on the A4. As rob says, the B6 190hp motor has it, but they're fairly rare. On the A3/Golf most cars were fitted with them after a certain year, so they're fairly ubiquitous, but the A3/Golf turbo doesnt fit the A4.
    IMHO your far better getting a hybrid built by beachbuggy, you can fit much larger parts inside the stock housings than you'd get with a K03s and you'll know its new.
    S3 or RS6 turbine and an RS4 compressor wheel and you should have a turbo capable of 250hp or so.
    C20LET injectors, 3 bar regulator and a VR6 MAF housing will go nicely with these parts.
    Mar 2012
    41
    Thanks for the heads up. I wasn't aware of the availability of the KO3s' so i may actually consider the option you mentioned. I've been looking at some Saab Red top injectors. Would I be correct in saying these would also work well?
    Is beachbuggy a resident on this forum?
    "Stick a V8 in it!"
    15,372
    yeh saabs are a little bigger but would also work.
    beachbuggy is a member, he also has a facebook page if you google for beach buggy turbos you'll find it.
  1. Undecided and need some knowledge/experience!
    By Jpd89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2012, 23:37
  2. Help needed with insurance knowledge
    By a4b8 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 15th January 2012, 20:43
  3. Turbo Bods! i need some of your general knowledge please
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2011, 13:21
  4. hello , need help with the mbc and n75 thingy
    By carbonaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2010, 17:40
  5. Looking to buy an S3, advice and knowledge needed!
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2010, 11:20
