EM TuningChris Nott
    Jan 2013
    59
    Low coolant warning
    Driving along today and the low coolant level light came on, stopped at the side of the road and found the bottle almost empty. I am unsure what could be the problem as I have changed the thermostat and coolant temp sensor and replaced all the coolant around 1500 miles ago. The temperature gauge stayed at 90 though.
    There's no leaks at all but this is the first time it has happened so will have to monitor it.
    Also when I stop after a journey and switch the engine off there's a strange gargling noise?
    The possibilities are heater matrix or the impellers on the water pump are damaged/failed?
    Any ideas?
    Thanks J
    May 2012
    RETFORD, NOTTS
    1,718
    could be an airlock making the gargling, if you have lost water, the pump stops pushing it around the system and its sitting still and boiling up. Sounds like it wasnt bled out properly when you did the work, and its now self bled and run low.
    Pressure test the system and check for leaks.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Low coolant warning not working.
    By @udi A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2012, 11:45
  2. Low Coolant warning
    By synthdood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th April 2008, 12:30
  3. Low coolant warning light on dash
    By mikerd4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2007, 16:30
  4. coolant warning light and buzzer.
    By imported_55spike55 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2004, 19:38
  5. S3 Coolant warning
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 21:02
