Chris NottEM Tuning
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By craigynett
Thread: Does anyone have VAGtacho in the York area?
    Jan 2012
    Malton
    272
    I need to sort out another key and I have a fob from the old car that I need to get programmed. I am wondering if any forum members have vag tacho in my area?
    thanks,
    Tom
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    280
    Add craigynett on Google+
    have you fitted a new transponder in the key? you can't program a used transponder from a different car, they're locked
    Please contact Admin if you wish to advertise your business/services on the forum
    Jan 2012
    Malton
    272
    Ah, thanks for your reply - I'll need to get a new blade with a new transponder chip - get the blade cut then reprogrammed the transponder chip. Am I right in thinking that I can reprogramme the old remote locking fob using the putting one key in the door and the other on the ignition method?
    craigynett's Avatar
    Apr 2006
    280
    yes, new cut blade, new transponder programmed with SKC using vagtacho or similar. Then yes you can program the fob with the manual sync procedure. I'm guessing the old & new cars are both 2000, if so then your old fob will be compatible
    Tom_B likes this.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Quote Originally Posted by craigynett View Post
    Craig. I beg to differ, I have just used VAG tacho to program a used key transponder from a golf onto a Passat to get it running after the original key was damaged. So it can be done.
    If it's any use, I have VAG tacho and will be on holiday near Pocklington from a week Monday.
    Currently rolling in a SKODA!!!
    May 2012
    RETFORD, NOTTS
    1,704
    Do you have genuine vag tacho or the Chinese 3.01?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    May 2012
    RETFORD, NOTTS
    1,704
    No doubt they were immo 2 in which case New transponder wasnt needed. For immo 3 cars you cant reprogram used transponders. So unless you know for sure, buy a new transponder to avoid disapointment.
    Buying new keys for the MK4 Golf \ Bora - uk-mkivs
    Immobilizer - Ross-Tech Wiki
    craigynett's Avatar
    Apr 2006
    280
    Jan 2012
    Malton
    272
    Thanks Arrkon -I will order up a new blade with a transponder chip just to be sure and it would be great if I could come out and see you to programme the new key.
    Arrkon's Avatar
    Oct 2010
    1,633
    No worries, should take me less than 20min
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    It seems a bit hit and miss TBH.
    I broke a 2.8 Quattro last year, and only having one key for my own car, decided to use the 2.8's key on mine. I got a blade cut, and used vagtacho or VCDS (cant mind which) to program the key using the SKC i extracted previously. My car has immo3, and it all worked fine, reusing the original transponder.
    However recently i tried programming a used VW key into a mates bora, and it wouldnt work. Everything looked normal thru the process, but the key simply wouldnt take the coding. Fitted a new transponder and that sorted it.
    Perhaps it worked for me because the "used" transponder was from an IMMO2 car?
    TD5 Land Rover Defender build
    May 2012
    RETFORD, NOTTS
    1,704
    I still wouldnt want to arrive at a car to reprogram and take that chance, do it once with the right tools imo. If that means a few quid for a chip so be it.
    Jan 2012
    Malton
    272
    Thats why I am ordering a new blade and the case bit with a new transponder chip. 25 quid all in cant be bad and, as you say, not worth taking a risk on trying to reprogramme an old chip.
  1. Replies: 0
    Last Post: 20th February 2012, 23:27
  2. Does anyone have any more pictures of the new facelift a3 s-line?
    By bumble in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th August 2008, 10:45
  3. Anyone in the York area have Vagcom
    By motosparkz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2007, 13:38
  4. does anyone have the LOUD miltec exhaust?
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2007, 15:54
  5. does anyone have a vag com in the north east
    By jase0851 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th July 2007, 18:09
