Volks AutosChris Nott
Results 1 to 18 of 18
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Low Oil Pressure Warning again!!!!
    Bit pi##ed off to say the least!
    I had the oil pump changed about 3 weeks ago, then tonight I get the warning again out the blue.
    Getting the right hump with this car now!
    Gonna have to see what the guy at the garage where it was done has to say I guess
    2000 1.8t quattro Sport totally standard (ish)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    id be checking the actual pressure with a guage, It could be a gummed up sensor giving a false negative
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Will do. It was my first thought last time so I got him to check it first and he said the pressure was very low so went ahead and did the pump. It seems exactly the same symptoms as before. Warning comes on at around 1800 rpm but goes out again by about 2500 rpm. This was after a motorway drive and with hot oil.
    Hope it's as simple as the sensor.
    Jul 2012
    Guildford
    97
    Is the oil pressure release valve part of the pump? if not you could have a weak spring in there causing low pressure.
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Does anyone have any more info on this valve, is it part of the oil filter housing? Can you just replace this valve thing?
    Guy at the garage is on holiday until a week on Tuesday so I'm a bit screwed for getting it sorted till then. I'm not going to risk driving it again so now I've got the nightmare of trying to find a car to borrow!
    Guess I won't know any more until I get that pressure test done but keep the advice coming lads please if you have any
    Apr 2004
    12,520
    pressure relief valve is part of the pump, the velve inside the oil housing is just a non return valve to keep the top end pressureised for as long as possible to prevent rattles on start up
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    To add insult to injury, I now have to drive round in a bright green Hyundi i20 but at least I'm mobile.
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Still waiting for a diagnosis from the garage. He did say he also replaced the pressure sensor at the same time he did the pump. So I still have no idea what the problem is. Could it be bearings? (all I can think of) are these known to fail?. Engine is as quiet as you would expect for nearly 180k
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    Have they put the correct grade oil in ?? As semi synth or mineral oil will sludge up quicker, also if you had sludge issues previously did they flush the engine out ?? All i can think off unless its a faulty pump ??
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    my mate had a hell of a time with his low level oil pressure light coming on. he also changed the pump pick up pipe extra and still had the problem. he was advised to use a genuine Audi filter he done this and the light stayed off it could be worth a bash..
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    My guess is they havent actually changed the pressure sensor, or they've fitted a cheap ****ty one.
    Find a new garage, it doesnt take a week to diagnose low oil pressure.
    TD5 Land Rover Defender build
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Quote Originally Posted by Kev
    To be fair it wasn't really the garages fault. He was away on holiday and I was 60 miles away from the car, plus I didn't want anyone else to look at it seeing as that garage had replaced the pump only 3 weeks previous.
    Fault traced to bad pressure switch that was replaced at same time as pump. Failed switch was a genuine Audi part too!
    So all back running sweet again, Phew!
    However, thinking of selling up now. I'm doing 14k a year in it and am in need of something a bit more economical on fuel. Currently thinking of a golf tdi 130
    Thanks for all the input as usual lads
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    Quote Originally Posted by NineNails View Post
    Dont sell!! Garage it as a weekend toy!
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    jbh
    jbh's Avatar
    TDi lover
    704
    The golfs are good cars.. make sure it has a good service history and has been run on the right VAG PD engine oil
    the PD engine isint as bomb proof as the old TDi engine with the mechanical pump but if looked after and serviced regular it should serve you well.
    my mate is a taxi driver and swore by the old TDi engine and said he never had one go seriously wrong yet the 2 PD engined passats he had both decided to go majorly wrong before they got to 200k
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Quote Originally Posted by jbh
    Funnily enough, I've just been reading about that. Thanks for the tip
    Quote Originally Posted by Sulli79
    Wish I could but can't afford the luxury of doing that unfortunately
    Aug 2010
    3,135
    Dont sell it lpg convert it for the week and stick to good old Vpower at the weekends
    jbh
    jbh's Avatar
    TDi lover
    704
    Quote Originally Posted by Bradderz_1988 View Post
    we had the octavia 1.8t 4x4 with an lpg conversion was a great idea but having to travel nearly 20 miles for the nearest lpg garage was a pita and to be honest with the way the price is going on the lpg and the fact you get reduced mpg on it we were finding it not worth our while.
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    It's a shame but I think lpg has had it's day. My dad used to run an old converted Rangey but he got rid coz the local garage got rid of it's gas. I don't think lpg ever really took off (in rural locations anyway)
    I've owned Audi's for 20yrs now and although it really gives me a heartache, I think it's time for a bit of a break. I will miss quattro so much though. I'm not in a great place financially just now and need a motor that can eat miles. I don't know that I'm doing the right thing and I know I could get a derv A4 but I've really had enough of A4's for now.
    Anyone wanna buy my bit rusty round the arches tqs?
  1. low oil pressure (red warning light on) loud rattling noise
    By ANTWAR72 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th August 2013, 09:20
  2. Low oil pressure light warning light
    By pawilliams100 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2013, 22:27
  3. Bizarre S3 Low Oil Pressure warnings....
    By KarlHeinz in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2012, 00:50
  4. Help! Low Oil Pressure Warning on 2.5 v6 TDi
    By Peanutmnm in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2009, 00:52
  5. 1.8T oil pressure warning - advice sought
    By imported_CurryMilkShake in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2004, 01:28
