Sky InsuranceBadger5
Results 1 to 8 of 8
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,087
    Vibrations? :-( 35mph+
    Having a nightmare with a vibration that seems to be coming from the f/n/s it feels like a wheel out of balance that starts at about 35mph and just stays. It really feels like something is loose in the suspension or steering but I've been under the car a couple of times and can find no play in any of the ball joints (which are all at most 18mnths old). When going down a bumpy road I get hollow clonk sometimes that you feel through the column and it wanders quite baddly on the undulating road surface and the transition between being on load and off load. It seems to be a continual fight to keep it pointing where I want it. Alignment and balancing has been checked and double checked and I've even swapped wheels front to back to no effect.
    Wheel bearings from what I can gather are the originals as the service history up to when I got it on 78k mentions nothing of them and I haven't touched the fronts up until the 165k that's now on it. Is it possible these could be the problem?
    Any ideas before I drop it on a VAG specialist? Fearing this could see the car being broken up if it can't be resolved :-(
    Life begins at 140mph
    www.passionford.com
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Try your inner cv joint.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    track rod end?
    2000 1.8t quattro Sport totally standard (ish)
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    The wandering is what i had replaced the tyres upfront and did the alignment and no more wandering, id go for the wheel bearing if you cant find any play/movement, whats the engine mounts like ??
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,087
    Will get car in the air tomorrow and check inner joints.
    TRE's were swapped out with Lemforder S4 items about a year ago.
    Tyres are good and alignment has been checked and double checked. Also swapped wheels front to back and viration stays at the front.
    To add insult to injury the old girl did not want to start this morning. Fired up on the key and died straight away then struggled to refire. :-(
    www.passionford.com
    Furkz's Avatar
    Apr 2013
    298
    while you are there check rims are not bent or cracked, also if you run split rims check their not loose... all in addition to the above
    Phantom Audi A4 B7 S-Line Avant
    Aug 2010
    3,136
    Starting could be the immo kicking in mine did this when i first got the car never done it since !!
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,087
    Checked for a flashing immo and all looked good. Just started it now and it died as soon as it fired but on second turn it fired and ran. Done a quick scan on my limited VCDS and the following codes appeared
    01367 - suspected central locking leak at pump
    01371 - No description shown
    01372 - No description shown
    01362 -
    Any ideas as being the unregistered version I can't see what they are
    www.passionford.com
  1. S3 vibrating exhaust?
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2012, 14:57
  2. Vibrations
    By simmolee in forum Handling
    Last Post: 5th January 2004, 13:11
  3. Question regarding vibration with spacers
    By spanishS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 06:08
  4. engine vibration through steering????
    By A3Lee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2003, 01:10
  5. Vibrate it!
    By A4Steve in forum General Chat
    Last Post: 12th February 2003, 18:05
