Volks AutosChris Nott
    Jan 2013
    11
    Changing front discs and pads on 2004 A4 1.9tdi
    Hi all
    New to this car maintenance lark and just wondering how long this job should take me and if there is any tools in particular I will require?
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    403
    You will need a brake caliper rewind tool or a piece of thin flat wood and a g cramp to push the piston back in and some times it advised to undo the lid on the brake fluid res as the fluid is forced back into it but be carefull it doen,t overflow.Time taken will depend on how long it takes to undo the caliper bolts and the harder ones are the carrier mounting bolt, use the longest leverage bar you can.
    Jan 2012
    Malton
    272
    One hour each side plus a cup of tea in the middle. Decent quality tools epsecially the allen bit to remove the pins that carry the pads. Watch out for the wear sensor cable and how it sits in its holder. Torque everything back up and enjoy one of the best upgrades that can done in two hours. Get your pads and discs from All German Parts in Leeds.
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    244
    Invest in a 7mm Draper Allen key brake tool. Essential bit of kit. Also Lockheed red grease (to lube slide bolts). Remember to thoroughly clean everything prior to installation, and wipe new discs with methylated spirit.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    You dont NEED the 7mm allen key, you can take the whole caliper off as a complete unit, and refit as a complete unit. Its worthwhile to use the 7mm key though, as it means you can take the sliders out, clean them up and regrease them.
    TD5 Land Rover Defender build
  1. How long to bed in new front discs and pads?
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2009, 12:51
  2. Front discs and pads
    By D8UGF in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2008, 10:43
  3. Front Discs and pads
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2008, 11:29
  4. 170 TDI front discs and pad upgrade?
    By richjohnhughes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2007, 23:32
  5. Recommendations for front discs and pads
    By andyhud in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th August 2006, 16:34
