AH FabricationsBadger5
Results 1 to 7 of 7
    Steve B5 Biker's Avatar
    Jan 2012
    SOUTH YORKSHIRE
    129
    Help needed please.... B5 AVANT
    Hi all help needed please... had a prang recently backed into a post and put big crease in tailgate along bottom edge, not repairable as it has rust bubbling through where the window seal is and body shops wont guarantee it wont return without major chopping out of the affected area,therefore making it a very expensive repair.
    Alas I have found a tailgate on the internet its from a 2000 w reg 1.8 petrol, problem is mine is facelift b5 and not sure if the one ive found will direct fit onto my car
    So need help identifying the body parts are same..
    Any help and advice much appreciated.
    Steve
    B5 Avant 2.5 tdi 2000 X reg , Jaspis green, carbon vinyl roof and door pillars, remapped, fmic, 18" bbs lm rims, custom exhaust, coilovers, RS4 front bumper and grill, tints allround, pillar mounted boost/oil pressure guages, solid flywheel conversion.....
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    498
    Should be fine, pre facelifts are some T reg and before. To double check if the handle is flush on both you are fine, bar paint of course!
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    WOLF's Avatar
    I am WOLF.......
    Apr 2013
    Doncaster
    666
    Anyone check part numbers on EKTA for you mate....
    Jan 2012
    SOUTH YORKSHIRE
    129
    Hi Steev done a bit of digging and pre facelifts are 98 back to 95... so it is same tailgate as mine just need to view it to make sure theres no rust on it otherwise not viable to paint.
    thanks for your input pal...
    WOLF's Avatar
    I am WOLF.......
    Apr 2013
    Doncaster
    666
    Glad to help mate
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Easiest way to tell, and the main difference, is facelifts have electronic boot pop.
    If your car has electronic pop, that one will fit.
    TD5 Land Rover Defender build
    Jan 2012
    SOUTH YORKSHIRE
    129
    Aragorn yes mine has elec boot pop, if by that you mean you put your fingers under lock where number plate lights are and just pull up and the boot pops open... by the way forgive my ignorance and thanks for the info.....
  1. Help needed please.... B5 AVANT
    By Steve B5 Biker in forum General Automotive Chat
    Last Post: 19th November 2012, 18:59
  2. Help needed please.... B5 AVANT SLIGHTLY MODDED
    By Steve B5 Biker in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th May 2012, 09:35
  3. Help needed, Please! Audi S3
    By jitvv in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2007, 00:51
  4. Help needed please!!
    By petephoenix in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2006, 00:25
  5. HELP NEEDED PLEASE
    By RAV in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2004, 11:58
