EM TuningAH Fabrications
    May 2013
    30
    Porsche cayenne calipers on S4 b5, will i require wheel spacers?
    I've done a search but can't find a definitive answer. I have a pair of 18z porsche cayenne calipers, ml55 discs ( centre bore altered) and suitable bolts/sleeves etc , my wheels are the 8jx18 avus rims, does anyone know if i will need wheel spacers and if so what size?
    Steve
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    485
    Not sure if B5s are any different but I run 10mm spacers with my Avus winter wheels on my B7. Could probably get away with a slightly thinner spacer but 10mms were what I had. I have to run 13mm spacers with my Speedlines, the 10mms had about 1mm clearance, too close for me.
    These are the only clearance pics I have with the Avus fitted.
    Alan
    May 2013
    30
    Brilliant, thanks for the reply. I think all things being equal ( same wheels, discs and calipers etc ) then 10mm spacers should give me the same result.
    I had intended to do a mock fit of the ML55 discs and porsche calipers today as i was doing a cv boot anyway, but was prevented from removing the caliper and disc by a rounded caliper bolt which i discovered some ham fisted babboon had left after a previous botched attempt. I will cut it off once i have the spacers as the bolts will be renewed then anyway.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Quote Originally Posted by S4Steve View Post
    to save cutting it off get some irwin sockets you smash them over and when you undo the rounded bolt the thread in the socket grips it on removal and they do work just make sure you have a breaker bar or a ratchet that has some leverage !!!!
    May 2013
    30
    Cheers, will bob down to machine mart and get a set, looking like the 11/16" one is favourite for removing the 18mm rounded bolt.
  1. Porsche Cayenne 18Z calipers, complete kit+discs & pads
    By reggieroo in forum For Sale/Wanted - Audi Parts
    Last Post: 30th April 2012, 00:50
  2. Porsche Cayenne Privacy Glass - Film or Actual Glass?
    By DPM in forum Other Brands & Models
    Last Post: 6th May 2008, 19:17
  3. Porsche Cayenne
    By Defratos in forum General Chat
    Last Post: 11th January 2008, 20:02
  4. Dog Bone Mount and Porsche Cayenne S brakes
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2005, 20:55
  5. Porsche 996 calipers.
    By Mcgough in forum General Technical / How To
    Last Post: 2nd December 2004, 14:51
