Volks AutosSky Insurance
    Jan 2013
    Darlington
    44
    Door rub strip removal
    Are the rub strips only stuck on? Or is the holes in the door for the strips to sit in. Fancy a bash at removing them.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Do you mean the lower door mouldings or upper mouldings, ive never removed the upper ones but the lower ones on the doors have a screw on the back side of the door then they just pull off to the rear of the car if you remove them and there the old metal runner type no doubt they will fall to pieces when they slide of as they rust and just crumble !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jan 2013
    Darlington
    44
    The top strip im wanting to remove. Not guna risk removing bottom leave that to the bodyshop. Wanting to smooth from bumper recess to. Anyone done this them selves?
    Jan 2013
    Darlington
    44
    Front bumper number plate recess.
    TDi Powerrrr
    Aug 2010
    North Devon
    401
    removing the rub strips will leave 3 or 4 holes in the door
    tony
    Jan 2013
    Darlington
    44
    Cheers or well guess i will leave them on.
  1. removing door bump strips..
    By filthyrich in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd June 2009, 21:11
  2. Door rubber strips
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2007, 19:47
  3. Side moulding (bump strip) Removal?
    By Jaywoo_A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2006, 15:40
  4. Door rubbing strips
    By Japper in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th March 2006, 10:13
  5. Door Speaker cover removal?
    By JSWD32 in forum In-Car Entertainment
    Last Post: 21st November 2004, 19:51
