EM TuningMonster Motorsport
    Nov 2005
    devon
    temp gauge not working
    my temp gauge is not working, the problem is i dont know where the temp sender is, is it on the rad? thanks in advance for any help!
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    Re: temp gauge not working
    At the back of the engine look behind the audi cover on top of the engine..
    Is either a Blue, black or green plug sort of thing (depending on the year) it is pretty small and will be on the top of a hose with black clip round it.
    I had to replace mine easy job.
    You will see it.
    If you don't post again and i will go and take a pic of mine.
    Cheers.
    Nov 2005
    devon
    cheers, mate, turns out the connecter has a wire broken out of it! so the connecter needs replacing along with the sender! how much did the sender set ya back?
    thanks again!
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    I am not 100% sure.
    My sensor was under 20 i am sure though.
    I replaced it about a year and a half ago.
    Not expensive though, just give audi a call and have you chassis number availiable and they will get you one in. You will be able to fit it your self.
    Also dont worry if the new sensor you get supplied with is a different colour because they were updated.
    Cheers.
