Volks AutosSky Insurance
    Jun 2004
    27
    Stiff drivers door....
    Drivers door seems o be getting stiffer and stiffer to open. Tried oiling the hidges but no difference.
    Anybody know what the little bolt under a black plastic cover does on the top door hinge???
    Milton Keynes UK
    248
    Re: Stiff drivers door....
    It tightens against the hinge pin to prevent the door from wobbling in the hinge.
    Try un-doing it and you will see what I mean.
    Jim.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    Try oiling with wd40 first, give it a good working, back and forth, it will free up, then oil with your normal lube for lasting effect
    mas
    Jul 2005
    n yorks
    128
    The hinges do wear on audis. Is the door perfectly aligned or has it sagged a bit ?
    If it is a worn hinge, a common cheap fix is to undo the lower hinge from the body and slip a washer in between the hinge and the body.
    Ideally you would replace the hinge, but I cant see how you would easily get it done without removing the wing.
