hop2407
Guys
On Saturday afternoon, I came to the end of a bypass to a roundabout and was going fast enough for a rolling acceleration in 2nd gear on to the roundabout, when it happened......
I put my foot down to accelerate and there was nothing there, no real power just a grumble as though I was only firing on 3 cylinders..... It sounds like a scooby with them flash exhausts (the burble) .......
So I have a problem.... every gear, there is nothing when I accelerate, seems like a misfire, it judders when going steady, and lumpy on tickover / revving when in neutral..... When I drive, I hear the turbo spool up / whistle, but no real boost....
Dont think it's a turbo issue at all as it occurs from very low revs.....
Lastly, If the car is left overnight or for a few hours it's fine for the first 500 yards or so, then it starts - I guess this is when the EMS has analysed fuel / air ratio etc... then makes adjustments (Badly)
What have I done - nowt.... other than fill up with opti on Friday - done about 30 miles after fill up before this started...
It is in the local garage (not dealer) this morning and he will hook up to the computer to see for error codes, but just wondered if you have any thoughts (MAF etc.).
I have not disconnected Battery yet (reset MAF / ECU etc.) because of my previous experience which I am sure you can remember (blown ECU) - however that time was just unlucky i guess.....
Thanks in advance chaps.....
