Chris NottEM Tuning
Results 1 to 8 of 8
    Sep 2004
    Irish (Living in Scotland)
    80
    Audi Concert Volume Problem
    Hi,
    I've noticed over the last week or so that the volume on my Audi Concert stereo is gone faulty. Turn it once and the volume goes up to the last. Turn it again and it shuts off completely. I did a search on here and it seems it something to do with a faulty microprocessor (to do with writing to a finite source of memory).
    As this seems to be an inherent fault with the concert I is it possible to install a concert II in its place. i.e. would this be a straight swap. Or should I jsu by another concert I and hope the volume issue does not happen again anytime soon.
    Has anybody else had the same issue.
    Thanks in advance for replies
    imported_kris_tdi
    Re: Audi Concert Volume Problem
    mine had this problem, essecially when it was cold.
    Jun 2003
    World of my own
    9,813
    Depends on which car the Concert II came out of. There are subtle differences to the fascia on TT/A3 & A4 models, so it may not fit properly.
    Technically all the wiring is the same.
    chazzy's Avatar
    Sep 2005
    bham uk
    95
    could be a silly question , how do you tell if its a concert 2? without removing from car. Its in an 02 A4. I;m trying not to change the vol too much, it would be good to know its not going to be a prob.
    i'm assuming B5 and B6 concerts are not interchangeable as i knowth concert od not the original one as the dealer had to recode it when i collected the car.
    chas
    Jun 2003
    World of my own
    9,813
    Concert 2 has a CD player instead of tape player.
    The fascia is completely different on the B5 & B6 A4's
    chazzy's Avatar
    Sep 2005
    bham uk
    95
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    you can be on my christmas card list. Mines got a Cd player.
    Now GF and I can play volume wars again..
    you know, loud, quiet, loud quiet and so on.
    Chas
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    was this not a common problem with the volume dodgy contacts in the dial? only solved with a new head unit if i recall from a thread on here
    Nov 2004
    London UK
    2,614
    My volume use to go up and then down and UP again of its own accord but that was last year it hasnt done it since on my concert stereo. Weird!
