AH FabricationsChris Nott
    Feb 2013
    huntingdon cambridgeshire uk
    42
    lower track control arm 1999 a4 1.9 tdi
    ive got to change driver side arm arm this weekend and only arms available local to me are a delphi or fai cant be without car only one in household which arm will be better choice ? ive read about meyle ars etc hd range but cant justify price at this exact moment in time other things going on at home
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,109
    Personally the price of a 'cheap' one is £20-30 less than a meyle, but for the price of a meyle you will probably spend triple the cheap one in the lifetime that a meyle would last so do it right first time !!
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Pretty sure you can get lemforder ones from euro car parts, and they deliver, as bradderz says its worth the extra as some of the cheaper ones have been known to fail within a couple of thousand miles!
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Feb 2013
    42
    will this do the job
    VW PASSAT AUDI A4 A6 A8 LOWER SUSPENSION CONTROL ARM MEYLE HD C846 | eBay
    i can wait till next week
    Aug 2010
    3,109
    Yup !!!
    Feb 2013
    42
    cheers and its cheaper than local place for the delphi one as that is 56 pounds and that meyle one is hd version for 42.50 delivered bargain
  1. Allroad 2.5 TDI 2001 Lower Control Arms Where to get?
    By Rossy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th August 2011, 17:12
  2. 100/A6 Front Suspension Track Control Arms - Replacement
    By deemde in forum Classic Audi Forum
    Last Post: 30th May 2006, 11:12
  3. Upper Front Control Arm
    By imported_Coullio in forum Handling
    Last Post: 2nd July 2005, 20:44
  4. When Control Arms are gone?
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th October 2004, 21:39
  5. control arms
    By squigly in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2003, 12:34
