Badger5Volks Autos
    Jan 2012
    Malton
    276
    Airbag controller recoding
    So I need to replace the airbag controller to get through the next mot and i just want to check that the code that i need to read off the old unit is called 'soft coding' in VCDS (highlighted in the snip) and that this is the code that I enter when the replacement unit is installed using 'Recode 07' (also highlighted below)
    thanks
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Jan 2012
    Malton
    276
    Turns out it didn't need recoding as it came out of the v6tdi and it all just seems to work. Off to get an mot this week.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,106
    Ive just replaced mine and the coding was the same, as the part number was the same as the one i removed (obviously lol) i had vagcom at hand and double checked and all was ok no more light for me and no more notchy seat belts !!
    Jan 2012
    Malton
    276
    Yes it's great when it just works! Does a dodgy airbag controller affect the seat belts?
    Aug 2010
    3,106
    No i had a front end bump that deployed the pre-tensioners hence replacing them so your seatbelts will be fine, well unless you have a bump then you will need another ecu aswel as seatbelts lol !!!!
  1. Problem with fitting airbag controller
    By Nige P in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2008, 09:02
  2. cruise control recode help
    By tonycb6 in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th June 2008, 19:25
  3. Airbag controller
    By andyhud in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th August 2006, 08:15
  4. Can Airbag Control Module be repaired rather than replaced?
    By Rhunster in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2005, 15:29
  5. Airbag Control Unit
    By bkmullin in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2004, 12:49
