EM TuningJMB Retrofits
    May 2013
    How to change a cam sensor?
    I have a 1998 a4 1.8t avant, and after taking it to audi for a diagnostic and service they said that there are 2 faults which are:-
    THE CAM SENSOR: Is this just a straight unbolt and bolt on job or is it more complicated than that?
    THE WASTEGATE VALVE: Think this is out of my league.
    Any comments and advice will be greatly appreciated thanks.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    The 1.8t cam sensor is two 10mm bolts and a plug. thats it.... 10min job
    It depends what they refer to as the wastegate valve, if its:
    • the N75 (electrical solenoid), fiddly but can be done quite easily
    • the Wastegate actuator, turbo has to come off to change it.
    • the wastegate flap (usually rattles), again, whichever route its turbo off. Either replace turbo, or as i did, find a good condition exhaust housing and swap it.
    Currently rolling in a SKODA!!!
    May 2013
    The code was N75.
    I'm not too bad with amatuer mechanics but i would'nt say im a professional at all.
    Do you think its possible to fix at home or is it best to take it to a garage,
    A home fix would be better as the garages are very expensive and also its a learning curve.
    Thanks for your help.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    N75 is an easy DIY fix. Could be a broken wire though, rather than a faulty valve.
    TD5 Land Rover Defender build
  1. How to change DPF Sensor??
    By Dannykn9 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2011, 22:15
  2. HOW TO CHANGE A ABS SENSOR
    By lostboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2010, 09:30
  3. How long to complete cam-belt change
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2010, 20:21
  4. how to change oil pressure sensor ?
    By AUDI@WRC in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th May 2008, 21:50
  5. how to change foglights bulbs???
    By indica in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th December 2003, 16:29
