Volks AutosAH Fabrications
    Mar 2013
    Belfast
    23
    If i change cluster will the miles be correct
    As above, my lcd is fooked, if i put a new cluster in will it read my miles still from the ecu or will it show the donor cars mileage? Cheers
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    The mileage is stored in the cluster, not the ECU.
    You can fix the difference with a Vagtacho interface.
    TD5 Land Rover Defender build
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    are the clusters coded to the key?
    Jun 2011
    Great Melton Norfolk
    1,349
    you will need the SKC for new cluster and to code it with vcds. If you dont have it,it can be retrieved with vagtacho or similar.
  1. Replies: 32
    Last Post: 22nd February 2010, 22:00
  2. Changing from kilometers to miles
    By tp7n in forum VCDS (formerly VAG-COM) forum
    Last Post: 21st December 2009, 10:12
  3. Will the new RS4 be a limited production run?
    By AndrewRichmond in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 23rd October 2004, 09:28
  4. WILL THE S3 RECARO SEATs FIT STR8 INTO A3 1.8T 2WD
    By lakhan in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2004, 01:49
  5. where will the creaks end? Bain of my life
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2003, 08:25
