Sky InsuranceJMB Retrofits
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: Changing turbo on 1.8t
    Oct 2009
    190
    I've got my replacement turbo and silicone TIP now looking at changing it this weekend, any tips/advice from experience to make my life easier?
    cheers jay
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,109
    Just be sure to prime the new turbo with oil, and be ready for the fiddly 8mm hex bolt that bolts the support bracket to the block its always gave me grief, make sure you have some oil to put back in as if you dont drop the oil and you realise that you cant get to the return pipe bolts at the turbo and only the sump the oil will go everywhere if you havent already drained it so word of advice would be to drain off the oil and also the coolant so that the job isnt caked in oil and coolant as you go along unbolting things.
    Arrkon likes this.
    Oct 2009
    190
    Yeah I'd planned on dropping the oil from the sump so oil change was going to happen, how long did it take from start to finish? Only ask because I only have Sunday to do it.
    Aug 2010
    3,109
    Ive done full turbo swap and manifold in about 5-6 hours but that was on my day off (done the job in work) wear time wasnt an issue and was the first one ive done on a 1.8T so was pretty much trial and error of what to take off and what not and way'ing up how to approach certain things and with numerous cig and brew breaks lol
    Oct 2009
    190
    Yeah I can feel a whole load of coffee/fag breaks! Do you know the part number for the larger oil filter? I know it's been talked about a lot just on my phone and the search thing get on my nerves. Oh and 5w40 oil is the one to go for?
    Aug 2010
    3,109
    5w40 is correct, i use the k&n hp-3001 which is the transporter size one, halfords is HOF259 or genuine is 074115561
    Aug 2010
    3,109
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    2000 1.8t quattro Sport totally standard (ish)
    Oct 2009
    190
    Cheers for all your help lads!! It's going to be a fun Sunday for me
  1. Changing Spark Plugs Audi A3 Turbo?
    By selector007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2011, 15:28
  2. Changing turbo?
    By glasgowal in forum Diesel forum
    Last Post: 2nd August 2011, 11:21
  3. acheiving maxium bhp without changing turbo?
    By Lacey123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2009, 00:27
  4. Changing turbo on A3
    By Sais in forum Tuning
    Last Post: 21st November 2006, 13:52
  5. Changing an injection engine to a turbo
    By 04061969 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th June 2006, 12:50
