EM TuningJMB Retrofits
Results 1 to 18 of 18
    Apr 2010
    48
    1.8 apt cranks won't start. Has spark has fuel
    Went to drive it earlier and zip. Turns over, has spark, stinks of fuel and plugs are wet so not pump. Scanned it with a mates bag style obd reader only got the code saying id pulled the battery.
    The word on the street could be coolant temp, but down the climate control check and it throws 30'c. Would cps lead to no fuel or would there be fuel?
    Any relays or other fuses I should check. Pulled 29 and that's fine.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    If the plugs are wet id say you are getting no spark, have you definately got spark ??, is the timing belt ok ?? Have you checked compressions. Whens last time you drove it/had it running ??
    Apr 2010
    48
    I pulled the two plugs that are accessible and tried them on the engine. Definite spark. Last driven yesterday. Timing belt is in 1 piece. Everything seems ok
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    Sounds like youve flooded it? Was the previous run VERY short? Like start, draw forward on drive and shut off?
    I presume it sounds "normal" when cranking, ie wub wub wub wub, as opposed to weeeeeeeeeeeeeeeeee or other odd noises.
    If you've got fuel and spark it should run.
    Jam the throttle into the carpet and crank for 15seconds and see what happens. Do not pump the pedal or otherwise **** around with it, just keep it jammed into the floor.
    TD5 Land Rover Defender build
    Apr 2010
    48
    Yeah like 10m!
    sounds normal just won't fire.
    Ill try that later.
    Would pulling all the plugs let it evaporate if that doesn't work?
    "Stick a V8 in it!"
    15,381
    10meters? That would do it. I think very short runs like that from cold cause the plugs to get fouled up, which means it doesnt fire and then gets flooded. I've had it happen a couple of times. Now if i have to move the car like that, i move it, then hold the RPM's at 3000 for maybe 5-10 seconds before shutting off, and that seems to stop it happening.
    You might need to clean the plugs up if it doesnt start, but full throttle should clear the excess fuel
    Apr 2010
    48
    Pulled all the plugs. Middle two cylinders damp. Checked the pack and ht for spark, fine. Pulled fuel off the rail 5' of distance on turnover. So not pump.
    Tried flooring it but not much joy. Airing with plugs out at the moment and gonna jump it as battery is dying.
    Apr 2010
    48
    Tried what Aragorn suggested. Turns over. Occasionally gives me one cylinder firing and car rocks. But nothing else
    "Stick a V8 in it!"
    15,381
    When it gave you one cylinder, did you keep the foot down and keep cranking?
    You might need to stick some new plugs in if they're badly fouled.
    Apr 2010
    48
    Yupp. Foot planted. Gonna see if plugs are wet again
    Apr 2010
    48
    Slightly but now as black as a black thing.
    Apr 2010
    48
    Next update.
    Am I right in thinking the fuel pump doesn't prime on 2nd key turn? Only when engine cranking?
    Pumping pedal with it being jumped results in a few fires and it almost sounding like it was going to go. Mate reckons fuel pump not enough pressure? You can just here and feel it when engine turning over. And poly cover off. But no noise on key turn.
    Can here and feel te relay click under dash
    Aug 2010
    3,138
    Im sure the pump primes every flick of the key can you actually hear the buzz from the fuel pump itself ??
    Apr 2010
    48
    "Stick a V8 in it!"
    15,381
    depends on the ECU.
    M3.8 primes every turn, but i think the newer ones dont (and APT is ME7 isnt it?)
    If the plugs are black stick a new set in. BKR6E's are cheap as chips.
    Apr 2010
    48
    They werent black until the foot to board test.
    It really tried to start, thanks for all the help so far.
    PS this is the reader im using, will it pull all codes?
    VAG405 OBD2 CAN FAULT CODE READER/SCANNER VW GOLF,UK SELLER - AUTEL ITEM | eBay
    Aug 2010
    3,138
    Isnt easiet way to tell is to see if it has a second lambda ?? And the style of connector the black D' shaped one ??
    you really need vagcom there good just for a quick scan and thats it, these cars can have problems and not even show codes so your best of having the full tool just incase it doesnt throw a code and you can read measuring blocks etc to see whats going on.
    Apr 2010
    48
    She's alive. Thanks fellas. Firstly I think it was flooded and when pissing around with the fuel relay it wasn't seated properly. Pushed it in again after trying to easistart and it fired but injectors weren't firing. Sorted
  1. HELP!! Car won't start! Cranks fine.. I'm seriously baffled now!
    By v12bug in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th September 2012, 15:06
  2. 2.5 TDI Quat won't start - electric pump in fuel tank help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2007, 10:41
  3. Car won't start in morning!!
    By JayA4Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2003, 23:25
  4. Car won't start in the mornings!
    By JayA4Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2003, 08:45
  5. Won't start!!
    By ray_nsm in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2003, 00:25
