Volks AutosChris Nott
    Jun 2012
    Ireland
    59
    Rear axle bushes
    Hi would anybody now if there is any upgraded rear axle bushes for 2wd 98 B5? cause i got just normal ones fitted about 8 months ago and they knackered. I would be happy to get solid ones. any help and advice would be helpful.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Try powerflex or just get standard ones from dealers.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jun 2012
    Ireland
    59
    Powerflex dont do rear axles bushes for 2wd. and i dont know how long audi bushes would last cause i have coiles.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    614
    If you need new bushes get them from GSF, bought mine from them and they were Lemforder ones , identical in every way to the factory Lemforder ones I took out, only about a tenner each IIRC..............shudder at how much Audi would charge for them!
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    I suspect the previous bushes have been fitted incorrectly, or were chocolate ****e.
    They MUST be tightened with the axle at normal running height, ie on the ground with the cars weight on it. If you tighten the bolts with the axle at full droop, they'll destroy themselves in no time.
    Get either genuine audi, or proper Lemforder replacements and you should be good for another 10 years.
    TD5 Land Rover Defender build
    Jun 2012
    Ireland
    59
    i didnt put them myself they were changed in decent garage. they look like installed correct but i thing they werent the best quality. I got them in GFS as far as i remember. Ill try to get good quality bushes this time cause labour isnt cheep to get them done.
  1. Removing rear axle bushes.
    By Dave Aston in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2010, 00:02
  2. a4 rear axle bushes
    By yendall24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th August 2008, 20:50
  3. Rear axle bushes worn
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st May 2006, 11:45
  4. A4 rear axle bushes.
    By a4avant in forum Handling
    Last Post: 28th November 2005, 21:16
  5. Rear axle bushes
    By Broken Byzan in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th November 2005, 14:46
