Monster MotorsportEM Tuning
Results 1 to 10 of 10
    Dec 2006
    barnsley
    1,016
    2.5tdi v6 avant engine issue (00575)
    a friend of mine has just bought a one owner 1997 2.5 tdi avant
    for the most part it is in very good condition , however after checking it over today ive noticed a couple of minor problems i can hopefully sort out with a little help
    im getting the 00575 vcds code come up when i scan the car
    firstly for not making enough boost pressure then after clearing and retrying for making too much boost pressure
    both of these are linked to the n75 valve
    this part has been superceeded a long time ago , what i would like to know is if i can fit a newer n75 off
    something like a seat leon cupra
    has anyone done anything similar to this ?
    the other problem i have noticed is the brake servo master cylinder appears to have been repaired at one time or another
    but unfortunatly this too has failed again
    is it possible to change just the clear plastic level indicator chamber or do you have to replace the entire unit
    many thanks
    nath
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jan 2011
    Aberdeenshire
    646
    For the boost problem, you need VCDS to test the N75 valve.
    Go to Basic settings, block 11 (IIRC) and with the engine running, it will cycle between actuator full up and full down.
    If you do not have VCDS, with the engine off, the turbo actuator arm should be away from the stop. When the engine starts it should pull the actuator to the stop.
    Try moving the actuator by hand - if it is sticky or restricted, go to the Mr Muscle Turbo clean thread on here.
    Another common fault is the hose to and from the actuator/valve/vacuum pump leaking/perishing.
    As for getting a different valve - why would you? It's a modulating valve so it is the control of it (ECU) that makes the difference, not the valve.
    Your brake reservoir can be changed on its own. Just pull it off. You do not have to bleed the system after changing it.
    When you next have a brake repair, be careful when using a pressure bleeder or you will be dong it again - they are prone to popping it seems, as a few of us on here have found this out the hard way!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Dec 2006
    barnsley
    1,016
    thanks for the reply
    ive been lead to believe inside the valve the seal can perish and this can cause running problems
    ill have another look at everything tommorow
    thanks again
    nath
    Dec 2006
    barnsley
    1,016
    have got the car on vcds now paul
    the measurements are slightly differnat for the n75 valve depending on which you use
    at idle the car is showing 90.3 duty cycle and goes down as you rev the car in the measuring block section 11
    in the settings section 11 the car cycles between just over 100% and 0% on the n75 valve (the only other thing i notice here is the maf reading goes through the roof )
    the duty cycle of the egr is only at 15% when at idle but according to vcds should be 40-75%
    maf actual is reading high at 329 mg/str
    Dec 2006
    barnsley
    1,016
    the full code im getting from vcds is 00575-11-10 .... control limit not reached intermittant
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Check all the vacuum pipes and look for splits or perished bits.
    Check the movement of the VNT shaft.
    TD5 Land Rover Defender build
    Dec 2006
    barnsley
    1,016
    ive checked the vacuum pipes and they appear to be working o.k as when you remove them you can feel the pipe sucking air
    ive sprayed some wd40 on the actuator shaft and it does now appear to move a little more
    the car is now not giving me a fault code but is still absoloubtedly flat as a fart , the turbo is definately spinning as its getting hot
    but i just cant feel it providing much boost and the engine is reluctant to rev beyond 3000rpm when you put your foot flat to the floor
    Jul 2007
    London
    3,235
    Change MAF...
    FOR SALE:
    Dec 2006
    barnsley
    1,016
    im gonna take the car out tommorow and do some logging off the measuring blocks to see what the car is doing under load
    Jan 2011
    Aberdeenshire
    646
    It does sound as if your vanes are sooted.
    With the engine off, the actuator should be away from its stop (fully down). When you start the car, the actuator should smoothly go up to the stop.
    If it doesn't move up, check to see if it is jammed, if not then look for vacuum leaks.
    If no leaks, then suspect the N75 valve.
    Once it is moving up ok, move on.
    Now go to ENGINE, BASIC SETTINGS on VCDS, and I think it is in block 11 - you'll have to check.
    The car will then cycle the N75 fully open and closed every 10 seconds.
    The actuator should move up and down smoothly full range.
    If not, then Mr Muscle it.
    If it does move up and down, try moving it by hand to see if you feel any grittiness/hardness caused by carbon in the vane rollers.
    If you suspect this, Mr Muscle it.
    Do a logging run to check for overboost.
    If you have a look here 2.5TDi Sluggish you might get clues on the logging (at the end).Read my graphs, and if you have a max 'dump' signal combined with an overboost, Mr Muscle it and check again.
    Once the actuator is confirmed moving correctly, then think about MAF sensor, rod length or stop screw settings.
  1. New shocks for A6 2.5TDI quattro avant
    By fjtwelve in forum Handling
    Last Post: 10th March 2012, 22:22
  2. 1995 A6 2.0 SE Avant - engine issues ?
    By auroan in forum Classic Audi Forum
    Last Post: 1st November 2007, 08:29
  3. Engine Issues
    By Scrappy in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2007, 22:42
  4. 2.5TDi hard suspension? engine vibration?
    By pmpants in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd June 2006, 11:53
  5. 80 tdi avant - engine change ?
    By johndavidwylie in forum Classic Audi Forum
    Last Post: 6th January 2006, 19:37
