Chris NottBadger5
Results 1 to 20 of 20
    Jul 2007
    341
    1.8T 180hp torque & remap advice
    Does anyone know how much torque a stock 1.8T AJL puts out?
    Im planing to get mine remapped, and although the K03 doesnt have much more to give by all accounts (another 10-20hp) I was wondering what kind of torque gains you could get.
    From reading up on the net most say its well worth it, as although the top end gains are not as big as some, the gains across the rest of the rev range are considerable. Is this right?
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Stock torque is iirc according to autotrader is 235nm
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    Yeh you'll mostly get a much better midrange, as you say, top end doesnt have much more to give.
    TD5 Land Rover Defender build
    Jul 2007
    341
    Is there likely to be a big leap in peak torque? AMD claim 25hp (opomistic) and 67lbft torque extra!
    2003 VW Golf GT TDi
    "Stick a V8 in it!"
    15,383
    yeh i'd imagine something along those lines would be about expected.
    You wont get over 200hp, even with exhaust/intercooler etc all upgraded you cant get over 200 on the stock blower.
    Jul 2007
    341
    Excelent. I dont really want to go down the route of a K04 etc, too much work for whats meant to be my daily.
    My plan is to replace the N75 with a new OEM item, all vac lines, check for boost leask, replace spark plugs etc, and then an AMD or Revo remap, 710N. May get an S4 arch liner too, as the stock intercooler doesnt have much of a chance with no venting from behind it.
    I also have an S4 exhaust system arriving today, which is aparently in 'excelent condition'.
    The only thing I'm undecided on is replacing the boost pipes. It sounds like I should look at a different intake pipe, but I'm tempted to replace the other 4. A boost test and new hose clamps as a minimum as theyre looking quite ropey.
    2003 VW Golf GT TDi
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    Might be worth putting a better turbo intake pipe on too, mine was quite flexible and collapsing when boosting restricting the airflow.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Jul 2007
    341
    Was that proving to be a problem with a remapped K03? Which pipe did you go for? I've seen some on eBay that look dirt cheap but no idea if they're upto the job.
    will add it to the list, I was undecided about that one, and also the 4 other boost pipes. I've noticed that 034 motorsport also do all the breather pipes, but that's probably not needed - maybe if mine are looking tired.
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    Quote Originally Posted by Mr K View Post
    i ran one of the ebay ones and never had problems with it apart from it did sort of catch the headlight a little but i had a k&n air filter so may have been pushed towards the front a little, its actually on ebay at the minute along with other bits and bobs.
    "Stick a V8 in it!"
    15,383
    i've got a silicone TIP on the avant and that touches the headlight, but its a big bore 3" one.
    I tilted the airbox over a bit, to try and help.
    Jul 2007
    341
    Bradderz - why have you swapped it out? Is the quality / fitment of the eBay ones ok?
    Aragorn - is that an eBay one too?
    2003 VW Golf GT TDi
    "Stick a V8 in it!"
    15,383
    No its a frankenturbo item, to fit a hybrid turbo and 3" MAF. Its a lot bigger than the normal ones.
    Aug 2010
    3,138
    ive swapped it out as im running the frankenturbo kit so was no longer needed as it wouldnt fit the FT turbo as i now run the same 3" TIP as aragorns and as for fitment it was ok.
    Jul 2007
    341
    Is a 2.5" or 3" maf worthwhile on a remapped KO3? I assume you just need the bigger maf enclosure/pipe and can keep the same MAF sensor?
    my OEM 'S4' exhaust systems arrived, its in great condition as I was promised. The down side is its actually a 3" RS4 system. So not only is it redicilously big for a 200hp 1.8, but its tail pipes won't fit in the valance. It does look like it will fit the floor pan, although I can't be sure. The down pipes are 2.25" so I could potentially use on the down pipes to connect it up, but I'm going to see about sending it back first.
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    You need a k04 frame or BT setup to run 3" maf and bigger injectors, stock blowers maxed out at 210hp and this can be had of a remap so fitting maf and injectors with a stock blower is just pointless.
    Jul 2007
    341
    Ok, cheers. I was wondering if there where any gains in throttle response. Will stick with the stock size MAF for now and get a hose to suit.
    The RS4 system is going back, and I have a 2.5" jetex exhaust on its way. Cant wait to get it fitted!
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    nice, get some pictures up before and after fitting the system you going resonated or non-res ??
    Jul 2007
    341
    Resonated. It's my daily and I want to keep it nice and subtle. Oem+ was always the plan, I just hope the tailpipes don't stand out too much!
    will defo get lots of pics!
    2003 VW Golf GT TDi
    Aug 2010
    3,138
    Think bigger tailpipes look standard tbh with some of the newer audis having bigger tailpipes like the millteks etc, i like it better than the pathetic pee shooters it had before hand so its all good lol
    heres mine with 3" twin rolled milltek -
    Jul 2007
    341
    Looks really smart! Will be very happy if it comes out looking as good as that. Mine are 80mm so not much bigger than that.
    Also for 034 diff carrier bushes in the post and meyle HD top arms! Should transform the car!
    2003 VW Golf GT TDi
  1. new turbo, remap advice and part number
    By ian 06 A3 2.0 tdi s line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th September 2010, 19:24
  2. remap advice for my mates a4
    By Lex in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2010, 12:48
  3. Remap advice
    By gaz71 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st September 2009, 10:20
  4. My A3 2.0Tdi is too slow - Remap advice needed
    By spandexx in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2008, 20:58
  5. (B5) A4 1.8T Sport Remap..advice
    By tracer in forum Tuning
    Last Post: 3rd June 2005, 12:36
