Chris NottSky Insurance
Results 1 to 14 of 14
    norad97's Avatar
    Jul 2004
    70
    Windscreen washer pump.
    Hi,
    The windscreen washers have stopped working, jets are not blocked and i blew down the tube from the bonnet and the
    the bottle bubbled.
    There is no sound from the motor, I looked at the fuse layout and it seems its the same fuse as the wipes and delay,
    so I guess it cannot be that.
    What about relays? is it the same relay for the wipers, just want to check before I take things apart,
    dont want to remove the wheel arch lining for nothing and find out its electrical.
    The bottle is not easy to get at from inside the engine bay, I think I can take the pump of the bottle but not sure
    how much wire is on the plug so I can dissconect it and test for Volts.
    A4 1.8T Sport 1997 Ming Blue:Tan Leather:Bose System: Milltek System: K&N 57i:Hyperboost valve:Smoke rear lights units:Upsolute remap:N75J Valve:AWE boost Gauge.
    norad97's Avatar
    Jul 2004
    70
    what' no replies at all, surely someone could help?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    pumps are cheap, throw a new one in and see what happens!
    TD5 Land Rover Defender build
    norad97's Avatar
    Jul 2004
    70
    Well, they are not cheap, My car has LCD display in the dash that show when water in bottle is low, these pumps are not £20.
    I took out the bottle today, removed pump and tested wiring for volts, found volts O.k., so off to GSF for the new pump, but when they
    showed me it' it was wrong and only 2 pins, I had my old pump with me and they could not mach it,the pump they sell it for standard car
    with no display info in dash. called TPS no stock, called the Stealers, no stock but £73.00 +vat !!!!!! so I took my pump apart a
    and found the motor seased up.
    sprayed with WD40 and bit started spinning freely, cleaned it up, put back in car and it works, water at last!!
    I realise this is only a temporary fix, need find a replacement soon.
    "Stick a V8 in it!"
    14,949
    Yeh i just fitted a non-sensor one to my old car when that happened, lost the low level warning but at least it worked!
    Newer models have a seperate sensor and pump.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    Check breakers yards or ebay and see what's out there.
    I would not want to lose my low washer warning.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Could the bottle be upgraded to take the new sensor on its own version?
    "Stick a V8 in it!"
    14,949
    no, sensor works differently on the new version!
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Not even modding the loom?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,889
    Is it only facelifts that come with the seperate sensor ??
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    14,949
    They changed over in ~1998, same time as they changed the clocks as depicted here:
    http://img217.imageshack.us/img217/9...lustersrev.jpg
    The earlier cars had a different washer and coolant sensor, which opened the circuit when everything was good, and closed it when washer fluid/coolant was low.
    I guess they changed it because "full" and "unplugged/broken" would then give the same "OK" signal.
    On the newer cars, the circuit is open when its empty, and closed when its full, which means they're not compatible, and also means "unplugged" flags an error, which is obviously useful.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    Thich is the issue I got at the moment with my coolant bottle.
    I can't plug my coolant level sensor in cause it beeps.
    I assume I can use it when I fit my new clocks?
    Jul 2007
    338
    On a FL avant, is it one pump that does the front and rear? I noticed that one of the non-return valves was leaking so was going to replace the pump.
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    norad97's Avatar
    Jul 2004
    70
    hi Aragon when u fitted standard pump with two pins, did the three pin connector fit?? what about the low water display
    on the dash, is off or on all the time,
    and what did you block the hole in the bottle with as it would be open??
  1. Rear washer pump
    By andy64 in forum Classic Audi Forum
    Last Post: 28th February 2006, 02:19
  2. windscreen washer tank problem
    By RichWalk in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2006, 10:57
  3. Leaking Windscreen Washer Bottle......
    By hop2407 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2005, 15:09
  4. Smell from windscreen washer
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2005, 20:03
  5. Windscreen Washers not firing?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 08:50
