AH FabricationsBadger5
Results 1 to 7 of 7
    Oct 2009
    190
    Intermittent complete power loss at 3k revs
    It's at 1999 1.8t, as title around 3000 rpm intermittently loose all power epc flashes up. It's quite abrupt and to be honest had the kids in the car so s**t myself quickly turned it off while rolling and restarted to normal.
    It's happened several times in 2 days.
    not sure if this is connected but feels like the car is gutless lately?
    any ideas folks?
    cheers jay
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Could be engine speed sensor or throttle body or the likes you need to get it scanned for faults and go from there.
    Oct 2009
    190
    Not as bad as I was expecting lol but yeah I'll get it checked once I find someone local'ish
    Oct 2009
    190
    Just thinking out loud really, I snapped a down pipe bolt recently which is blowing about 80% of the exhaust fumes out of that gap. Would that be enough to mess with the sensor in the cat and cause my running issues.
    new turbo on its way Wednesday so I'll be sorting the down pipe/cat at the same time
    Aug 2010
    3,138
    Mine had a cracked manifold right before the turbo and through a 00531 mixture code but didnt cause limp mode or lack of power, iirc the epc light is nothing to do with emissions but is an electrical/mechanical fault on the engine which will cause limp mode to avoid damage to the engine, and the actually engine light only come on in severe cases like if the timing is out by a faulty CCT or the likes.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    EPC light means you've got ME7
    There should defo be a fault code stored, pissing into the wind trying to guess without looking to see what the fault code says.
    TD5 Land Rover Defender build
    Oct 2009
    190
    It's all good oranoco is going to scan it in the week. I'll post up what codes I get when it's done
  1. Power loss at low revs when cold 1.8T
    By dayofthejackal in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2014, 12:46
  2. Glow plug light and complete power loss
    By norm29 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2011, 12:15
  3. s3 complete power loss
    By Lacey123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2009, 23:59
  4. Power loss at high revs
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2006, 12:39
  5. S3 Instrument Cluster - Intermittent power loss
    By imported_G123 in forum General Technical / How To
    Last Post: 11th October 2004, 20:15
