Volks AutosAH Fabrications
Thread: B5 S4 Brakes
    nemo2182's Avatar
    Lord wont u buy me a V10 R8!
    Oct 2005
    uk
    110
    B5 S4 Brakes
    Now I've had several conversations in the past about what can and can't be fitted onto a B5 S4. Does anyone have a breakdown of what calipers bolt straight on a S4, I.E. B5 RS4 etc, and what can be fitted with what carriers etc etc.
    Im looking at changing the discs on mine again, and a good set of aftermarket discs cost £200, so seeing if there are any B5 RS4setups going cheap anywhere. Also found some very nice looking porsche Cayenne claipers on ebay for £200, very tempting, but need to know what sort of costs and work is involved.....
    Many Thanks
    2000 B5 S4 - MRC Remap - RS2 Sparks - Pipercross Element (dried) + Modified Airbox - Forge Divs - Samco Hose's - KW's dropped 50mm - 18" RONAL R41 in gun metal grey - Black Diamond Combi Disc's + Predator Pads - Brushed Alloy Mirrors - Short Shifter - Full Recaro - Carbon Trim - Bose. More to come, watch this space.......
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    S4 B6 calipers and discs are straight bolt-on iirc also cayenne turbo calipers with Merc ML discs iirc
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Apr 2009
    west London
    35
    Quote Originally Posted by Bradderz_1988 View Post
    Do the front S4 B6 Callipers need TT Carriers or do they really just go straight on?
    Many thanks
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    B6 stuff bolts streight on. You need the carriers from the B6 though, but those should come with the calipers.
    TD5 Land Rover Defender build
  1. Front brake pads
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 16:30
  2. Brake Fluid
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 23:39
  3. Smoking Brakes
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 18:42
  4. S3 Brake Upgrades - not Porsche/Brembo
    Last Post: 25th January 2003, 17:05
  5. Brake Pad Upgrade?
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 05:19
