AH FabricationsSky Insurance
    Nov 2012
    48
    Question Help choosing a tyre size! :)
    Hi all,
    I've just bought myself a set of 17" wheels for my A4 B5 off ebay.
    The offset is ET40 (as opposed to the standard ET45); and the rim width is the same as my 16" ones at 7J.
    I'm looking to fill as much of the arches possible, and bring the speedo over-read down.
    I'm therefore looking at 215/55/17; will this sit ok without rubbing on the suspension components?
    Cheers,
    Grant
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Id probably suggest either a 225-45-17 or a 215-45-17 personally to fill the arch you would be best off getting a set of 18" alloys and a subtle drop.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    As above really. I imagine that 55's will be a bit ballon like in those sizes.
    I'd opt for 225/45/17's myself.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    225/45R17 is the standard factory fitment for 17" rims on the B5.
    225/50R17 scrub on the arches, and look a bit stupid, as my brother had some on the car as winters. 55's would be even worse.
    The speedo overread is intentional, it overreads by about 5mph right across the range deliberately, due to the law which states they can overread by upto 10% but cannot underread at all. To cover themselves, they calibrate the speedo in the middle of the range.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    225/45/17 is what I ran on my old RS4 reps.
    Life begins at 140mph
    www.passionford.com
    Nov 2012
    48
    Cheers folks! Gives me some ideas at least...
  1. Help with tyre sizes for staggered wheels!!
    By Tom Mineral Grey S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2009, 00:39
  2. Tyre size help
    By Cruz in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2009, 22:40
  3. Tyre size help please
    By norad97 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2007, 19:47
  4. Tyre Sizes Help Needed???
    By lUCKYS3 in forum General Chat
    Last Post: 27th March 2007, 21:36
  5. i wanna ask about tyre sizes......need help plzzzz
    By One in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2004, 21:42
