JMB RetrofitsChris Nott
Results 1 to 26 of 26
    Oct 2009
    190
    Snapped bolt going into turbo
    Basically I was fitting the decat 1st thing yesterday morning so I was half asleep and snapped the bolt that connects the cat to the turbo, I've got about 2-3 mm of thread sticking out of the turbo. Could that be drilled out or does it have to go to turbo specialist. I'm not looking to spend a lot as the penny valve is f**ked. I plan on getting a beach buggy hybrid in the summer.
    Unless someone has a spare k03 knocking about for cheap just need it fixed before 5th of may because I really had my hopes up for BHP show on the 6th.
    cheers jay
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Can you get a hacksaw/angle grinder in there? If so you might be able to cut a groove get a flat blade in there. You've only snapped a bolt so no need to get a turbo specialist on the case. There are loads of bolt extractor type tools though available. Check eBay.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Oct 2009
    190
    That's a bloody good idea mate. I'll give the angle grinder a go. Cheers
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Don't go too far into it and crack the turbo housing, though
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Why not try wind a nut on the exsisting thread and welding it to the stud then use a socket or spanner to try and remove the stud ??
    Oct 2009
    190
    That would be the easiest option if I had access to a welder
    boost-addict's Avatar
    Aug 2011
    977
    were are you located steady? im in sevenoaks, and have a welder, your likey lightyears away some were up north!
    also thinking if i work the weld in both sides of the nut then imediatly turn it off the heat should be enough aswell. i got some plusgas (decent penetrating fluid)
    so if your not far ill be glad to help. i also have a k03 that id lwt you have but the bearings have siezed and its destended for a hybirid any how!
    also i fitted a decat so can give you hand on that front. but i must warn you the car become very raspy down low and drones alot, but then i only have a single rear box, 2.5" system made up by me, need another one if i can
    Oct 2009
    190
    Hi mate I'm in Welwyn garden city, Hertfordshire not a squillion miles but still a good hours drive. Not too bothered by the drone already have a 2.5" milltek non res. my last a4 had 2.5" custom with decat but with stock d/p which was much quieter. Think I've not got enough time to get all the things done before BHP show. Still have forge map sensor and all new red silicone hoses for fmic to fit and a passenger door I got from the scrappy. "Yeah right" says mrs steady jay
    Aug 2011
    977
    yer 60 mile! even if you hire a small mig or arc welder for the say its like £40/50 cheaper then a turbo guy or a garage
    Oct 2009
    190
    How can I find the part number of the bolt I snapped? I went into audi in Watford and got completely ignored for half hour so I'm f**king fuming. my local vw/audi independent shop said its main dealer only so I'll give vw a go which round the corner, if I can get the part number.
    thanks jay
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,642
    think the part number is N 0445203 its an M10x28 Stud...
    Currently rolling in a SKODA!!!
    Oct 2009
    190
    Can I get away with just using the correct size stud? Instead of using the proper one that has 2 different direction threads.
    Aug 2010
    3,136
    You could just use a stud thats a similar size and thread even if its slightly longer than the other 2 so long as it doesnt hit the cat.
    Oct 2009
    190
    It's decatted so nothing to hit really, think I could just stick 2 nuts on the end so there no chance of working itself out
    Aug 2010
    3,136
    One nut should be enough.
    Oct 2009
    190
    Ok fair enough cheers
    Jul 2007
    London
    3,240
    See this link at Darkside Developments: M8x20 Exhaust Studs - Darkside Developments
    FOR SALE:
    Aug 2010
    3,136
    You could even knock the thread closet to the turbin housing just to stop it coming loose with a centre punch.
    Arrkon's Avatar
    Oct 2010
    1,642
    Quote Originally Posted by adamss24 View Post
    that has me worried where it says "Special VW size exhaust studs"
    I need some too lol...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    turbo to downpipe studs are M10 i think, certainly bigger than M8!
    TD5 Land Rover Defender build
    Aug 2010
    3,136
    M8 are probably the manifold cylinder head studs.
    Oct 2009
    190
    Got some from vw in the end, hasn't helped though that snapped one is pi**ing me off now!
    Aug 2011
    977
    have you not tried putting another nut on there?
    Oct 2009
    190
    Can't do much with it though, I'm rapidly running out of time so I might whip off the whole turbo and carefully drill it out.
    Aug 2010
    3,136
    Maybe try getting some heat on the stud and try removing it with vise grips if theres enough thread to grip on to. I had to have mine redrilled and tapped cost me £40 from my works local engineers shop.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Captain Obvious says... Have you tried a stud extractor?
    Something like this: SEALEY VS7232 STUD REMOVER / EXTRACTOR & INSTALLER 6 - 19MM FOR 1/2" DRIVE | eBay
    Mo power, mo problems
  1. car keeps going into limp mode please help.
    By Steveo_A3_1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2011, 17:48
  2. SYMPHONY LL RADIO KEEPS GOING INTO 'SAFE' MODE
    By KCAS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2011, 08:39
  3. Going from turbo power to naturally aspirated - thoughts
    By monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2007, 13:18
  4. Crunch going into third gear?
    By S3K in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2005, 17:36
  5. Going Into Limp Mode
    By johnboy1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2004, 17:55
