EM TuningChris Nott
    Sep 2010
    62
    1999 S4 B5 wiper stalk
    Hi All,
    Does anyone know the part number for the indicator/wiper stalk assembly. The wipers are now only working on the medium setting, i have replaced the relay some months ago. So I'll just replace both sides, as the reset button wont work either.
    Thanks,
    Rob
    Dimokslis's Avatar
    Oct 2011
    Wembley/LTU
    48
    Add Dimokslis on Facebook Add Dimokslis on Google+
    Estate or saloon?
    Edit - Should be these ones:
    Estate 8D9 953 503 D
    Saloon 4D0 953 503 B
    This is just a wiper stalk.
    Sep 2010
    62
    Its a saloon,
    Thanks a million Dimokslis. Much appricated
    Sep 2010
    62
    Audi steering column switch part number: 4D0 953 513 D
    Audi Wiper Switch Parts No.: 4D0 953 503 B
    Hi all,
    the wiper stalk is correct. but can someone confirm if the 513 D is the correct part. Might as well replace both. 99 S4 B5 saloon
    Lenkstockschalter Audi A4 B5 ( Typ 8D ) 4D0953513D 4D0953503B Wischerschalter | eBay
    Thanks in advance again
    Rob
    Jan 2009
    Up tiddly up up
    71
    Don't forget the obvious, as I nearly did yesterday when I purchased my new wiper stalk...
    If you have the Avant, dont forget the Saloon one will not have the rear wiper setting....
    Remembered just in time!
    Sep 2010
    62
    Replaced the stalk and it was the same, the only thing was that the LCD came back on, which seems to have been the stalk. (The red part of the LCD)
    I reseated the wiper relay and that sorted it.
    Does anyone know if the steering wheel bolt has a torque value? It was welded in there and that how I put it back on. Very Very tight
  1. Wiper Stalk Wiring
    By RodA in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th August 2011, 20:58
  2. dis wiper stalk?
    By sline29 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th January 2011, 12:08
  3. Wiper Stalk for DIS?
    By Fast3000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th March 2009, 10:27
  4. Removing Rear Wiper Stalk
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2007, 17:29
  5. Wiper stalk problem
    By steve1975l in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2007, 10:05
