Sky InsuranceBadger5
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    399
    1.8 QTS down on power
    I feel that my qts is a little sluggish for what is supposed to be 180bhp. Are there any common faults that could be causing me to loose power? DV, boost leek, egr etc?
    I'll be getting the car rolling roaded in the next few months but would like to try and improve things a little beforehand if at all possible.
    Oct 2012
    425
    If you can get the codes read by someone, that's really the first step, could be something simple like a dv valve gone had that last year on the mrs's car when we bought it.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,109
    Replace all the vac lines and DV like ian said get the codes read too could be maf related, also get a boost gauge fitted to check your seeing correct boost pressure as mine was showing 6psi instead of 12psi and turned out to be the wastegate penny valve in the turbine housing being totally fubar'd.
  1. down on power / hesitancy
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2008, 11:13
  2. Missfire, coilpack change now down on power
    By Timmc in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2008, 18:19
  3. Down on power ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2006, 16:37
  4. Down on power sometimes
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2006, 11:36
  5. Down on power?
    Last Post: 18th January 2006, 12:16
