Badger5Monster Motorsport
Results 1 to 25 of 25
Like Tree1Likes
  • 1 Post By aragorn
Thread: vcds help
    Feb 2013
    southampton
    43
    vcds help
    in need of some help i get a prob with laptop talking to car it seems can anyone explain to a thick fck vcds prob.jpg
    how to solve the prob or anyone local to southampton able to show me for beer tokens
    thanks les
    i plug blue lead in start up vcds program turn ignition on the click port 3 and test and thats as far as it go,s
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    turn ignition on then start the vcds
    is it a genuine VCDS
    Feb 2013
    southampton
    43
    no its the one scott said to download from a usa site the guy that does vcds lite and stuff
    bez101's Avatar
    Jul 2008
    8,520
    no idea then
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    is the lead actually using port 3?
    Look in device manager...
    TD5 Land Rover Defender build
    Feb 2013
    southampton
    43
    yes it is aragon got my computer mate to check he said cars not talking to comp?
    2,175
    From your screen shot your not using the lite version! 11.11.5 is the full version
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Try it on all the com ports it should read - interface : ready !
    id also check that its been installed correctly with the disc that comes with the lead, check your pins on the eobd connector make sure theres not a bent one !!
    Aug 2009
    Stoke on Trent
    114
    if its a copy lead then remove the current vcds and goto the official site -> downloads and you should see a link for 3rd party leads
    Download the software and try again... that worked for me, but in all honesty all you can do is reset the abs and maybe a few more little things.
    My lead went in the bin its that useless, better to spend some cash on the full tuxedo
    If i told you i have to kill you, but i could give you a clue and just rough you up a bit!
    "Stick a V8 in it!"
    15,383
    If its a standard ebay Blue lead, you should be using VCDS Lite, VCDS11 is only for genuine cables afaik.
    The cheap cables can take a bit of prodding to get working, but they usually work just fine.
    You NEED to open device manager and see what com port the USB serial bridge is using, and choose the same option from inside VCDS.
    Also, you said "the cars not talking to comp", when infact the error you've got means the computer cant talk to the interface, rather than the car itself.
    Steve_D likes this.
    Feb 2013
    southampton
    43
    ok will get my friend to try all posted ty guys
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,014
    Don't forget to make sure the ignition is switched on.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Feb 2013
    southampton
    43
    sticking in audi chandlersford tomoz to get sorted as my friend away fishing £90 to plug in and tell me faults is not to hellish
    bez101's Avatar
    Jul 2008
    8,520
    £90 **** that
    has the car got the light on ?
    Feb 2013
    southampton
    43
    turn airbag light off and get print out of fault codes
    Feb 2013
    southampton
    43
    ok sort figured it out can someone tell me what codes meanfault codes.jpgvcds result.jpg still need to figure how to turn airbag light off but im new to this
    bez101's Avatar
    Jul 2008
    8,520
    to smal copy and paste
    Feb 2013
    southampton
    43
    any better?
    bez101's Avatar
    Jul 2008
    8,520
    best way is to clear all codes
    then rescan see what come back.
    they may be old codes.
    Feb 2013
    southampton
    43
    so click clear results and re do it?
    bez101's Avatar
    Jul 2008
    8,520
    yes clear them all
    take for a drive and see what comes back
    Feb 2013
    southampton
    43
    ok cleared codes taken for a drive plugged back in same code,s showing as above
    and found why airbag light is on now module needs recoding and both front seatbelt,s are showing high resistance the reels in pillar need changing phoned audi no longer avaible grrr
    looks like time to get rid unless i can find some s/h belts that have no fault but then off a breaker i cant plug in and test
    Feb 2013
    southampton
    43
    are facelift seatbelts the same??
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,014
    Quote Originally Posted by les-ward View Post
    Pre-facelift seatbelts never had the sensors or anything in them I don't think.
    I can't only assume all FL belts are the same.
    "Stick a V8 in it!"
    15,383
    The belts are different but interchangable.
    I have PFL belts in my FL as mine had been crashed and the pretensioners fired. Got some PFL ones for buttons on ebay.
    The autoscan you've done is a bit messy, i always just open the specific controller and query it directly. Far easier to see whats going on.
    You've also not cleared the DTC's, as that buttons greyed out on your screenshot. All you've done is cleared the results of the scan.
    Forget autoscan, open the engine controller, reset the codes and take for a drive for half an hour and see what comes back.
    Do same with the airbag (though you wont need to take it for a drive, just exit the controller, cycle the igntion, and go back in again)
  1. Some VCDS Help
    By sohail579 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2011, 02:10
  2. How to Reset my ECU Help Required and some VCDS Help
    Last Post: 17th August 2011, 13:04
  3. VCDS help on a MY10
    By grimp in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2011, 16:37
  4. VCDS HELP
    By RallyX in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2011, 20:23
  5. Major VCDS Help, I changed the coding i should not have!
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2011, 17:31
