EM TuningAH Fabrications
Results 1 to 11 of 11
    Apr 2010
    South Yorkshire
    147
    A4 B5 Windscreen wiper change
    Hi all,
    Do the newer version Audi wiper arms that carry the aero wipers fit the b5 shape?
    Mine are poor and look to upgrade if possible. I can't seem to find a thread on here that says so
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Passat B5.5 are a direct replacement.
    No messing about.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    Yeah as Scott say passat 5.5 ones are a straight fit, the only thing to watch for is if you have the bonnet up and the wiper get switched on they will foul and take the paint off your bonnet!
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    Took a trip to a scrappy in Hertford and 2 in Brentwood and no joy with a set of Passat arms.
    Life begins at 140mph
    www.passionford.com
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    614
    If you just want flat blades then there's no need to change wiper arms , fit Bosch Aerotwin retrofit blades.
    They are flat blades but still retain the hook-type arm fitting.
    Some don't like them, but I've used them on my car since 2007 and think they're great.
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    nogmeg's Avatar
    Jul 2012
    Raveningham, Norwich
    34
    I use the bosh aero blade too, but the only complaint is the plastic clip is massive, unlike getting B5.5 arms. here are some part numbers.
    • 3B1 955 409 C (2001 Passat B5.5 Arm) - lhd drivers arm
    • 3B1 955 410 C (2001 Passat B5.5 Arm) – lhd passenger arm
    • 3B2 955 409 B (2001 Passat B5.5 Arm) - rhd drivers arm
    • 33B2 955 410 B (2001 Passat B5.5 Arm) - rhd passenger arm
    • 3B0 998 002 A VALEO AEROBLADE SET with wear indicator, FRONT
    • 1K9 955 427 AEROBLADE REAR (2010 golf variant)
    • 1K9 955 707 A/03C PLASTIC ARM (2010 golf variant)
    • 6Q6 955 435 D REAR JET CAP (2010 golf variant)
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Quote Originally Posted by Nessy View Post
    i use the Bosch ones but they tend to last 6 months before they start to streak like mad going to go for the passat ones myself as the Bosch ones tend to make the arm sit quite away from the screen.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    Trico neoform wipers from opie oils are another good choice if you want to retain the standard arms. They are normally on offer also iirc.
    Pic of the wipers fitted
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    Been using the Bosch retrofit aero blades for about 18 months. Very pleased, no streaks. I want the Passat ones as I think they look that bit neater.
    www.passionford.com
    Apr 2010
    South Yorkshire
    147
    Update on this, it is becoming a struggle to find Passat arms so far
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    450
    Yeah they are hard to get second hand, I bit the bullet and got a kit of eBay, not sure they still do them though. You could try a vw dealer for prices?
  1. A3 Windscreen wipers
    By RevoKev in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2005, 10:55
  2. Windscreen wiper motors....
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2005, 10:02
  3. Lifting windscreen wipers when washing!
    By benw123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2005, 12:59
  4. Clever windscreen wipers - or bust?
    By imported_katetodd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2004, 19:58
  5. Special Needs Windscreen Wipers
    By AndyMac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2004, 12:08
