Volks AutosEM Tuning
Results 1 to 7 of 7
    East Berkshire
    178
    OBD coolant temperature readings
    I'm trying to find the post from a couple of months back ( I think). I've just spent ages searching - no luck ( but lots of other interesting stuff !! )
    Can anybody help please.
    B5 1999.5 (facelift, July 1999 registration)
    I wish to check the coolant temperature via the climate module - there use to be lists of 'what and how' floating around years ago-- I suppose too many cars have gone to the scrap yard so it's no longer a hot topic!
    Thanks .
    ChrisG
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    Press and hold the recirc and up arrow together, the screen should get brighter, and show 1c.
    use the temp buttons to go to 49c then press recirc again and it should show the temp.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    East Berkshire
    178
    thank you very much!
    ChrisG
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    No worries, can't remember what the other channels are, so would be good to find the full list.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    Quote Originally Posted by Sulli79 View Post
    Full list here.............
    AudiWorld Tech Articles
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    watch though as some of the lists floating around dont match perfectly with the B5 climate unit.
    That one linked for instance says 49 is a malfunction counter for the speedo, and 51 is temperature which isnt correct. 49 is "raw" temperature, and 51 is some sort of virtual temperature value that doesnt really match up with anything.
    TD5 Land Rover Defender build
    Jun 2011
    73
    Aragorn is definately right there - some of the list do vary in what they say and don't really match up to some things which they say they do - 51 for instance is listed on a few as engine oil temp, but if you run the engine from cold with this code showing on the climate panel, you will see very quickly it will hit 90 deg when your oil temp gauge is not really moved from 60 deg!!
  1. Coolant Temperature Guage
    By filipharvey in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd May 2008, 16:20
  2. Coolant Temperature Guage
    By filipharvey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd May 2008, 21:58
  3. coolant temperature sensor problem.
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2008, 15:10
  4. G62 Coolant Temperature Sender - Replacement guide
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2007, 20:40
  5. trouble code coolant temperature below normal?
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2004, 05:36
