Chris NottAH Fabrications
Results 1 to 14 of 14
    Oct 2005
    Forfar
    31
    Service resetting
    Is it quite easy to reset the flashing service sign that comes up on the dashboard?
    If so can someone tell me how to do it as the garage who have just serviced my car didn't bother. Ta
    imported_kris_tdi
    Re: Service resetting
    tells you how to do it in the owners manual.
    Oct 2005
    Forfar
    31
    Not according to my manual. On page 63 it tells you the meaning of the 3 service indicator and then goes on "The display is reset by the audi workshop once servicing has been carried out".
    Anyone else please?
    Jun 2003
    Hythe, Kent
    1,180
    I know the details have been posted before but I can't find the post [img]/ubbthreads/images/graemlins/frown.gif[/img]
    I can also confirm that some manuals do state how to and others don't.
    I can't remember if mine does or not - I'll have a check in the morning for you.
    Kev.
    imported_kris_tdi
    ok what you do (funnily enough just reset mine today)
    Pull out button 2 (ie one nearest drivers door)
    Turn ignition On
    Release button 2
    Press button one to select if you want to clear oil change or inspection service
    press button 2 to reset that one
    turn ignition off
    when you turn ignition on again it should have cleared it.
    Oct 2005
    Forfar
    31
    Thanks Kev, just tried that and for some reason I can't fathom, it ain't working.
    Maybe I'm a dumbass but its a '97 A4 tdi quattro. I did what you said about pulling button 2 but it didn't seem to move and from then on nothing made a difference. "In 2" still flashes.
    Maybe I should set fire to the car, that would get rid of the service light! :-(
    imported_kris_tdi
    did you make sure the ignition was off first?
    have to pull button 2 out then turn ignition on.
    imported_kris_tdi
    it should pull out, infact both of them pull out, when you pull button one out it does a fault check to make sure everything is working ok,
    Jan 2004
    Northern Ireland
    34
    I think this depends on the year of your car
    Mine is a 1996 A4 1.8T Sport for example and this procedure does not work
    The indicator reverts back to the trip reading after about a minute
    Dermot
    Oct 2005
    Forfar
    31
    Dermot, that's exactly what mine does. Kris' point about the fault check is different on my model as you push the left button to get a check and not pull it.
    imported_kris_tdi
    fair enough, i dont know then.
    mine is a 1st facelift 1998 model (not the one they did when changed headlights etc... though)
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    You need to re set it via vag com. .
    1996-1998 models require the interval to be set back manually.
    Info on the ross tech site if you have the means of a VAG Com cable, and if not, post a request in the vag com forum.
    Nov 2004
    England, UK
    63
    yes in this case you need vag-com cable and software. Is fairly simply to do, mate of mines did it for me.
    Oct 2005
    Forfar
    31
    Thanks, getting it done later this week. Cheers for everyones assistance
