Results 1 to 18 of 18
    Jan 2013
    kilmarnock
    12
    Thumping noise when breaking ???
    Hi Guys ,
    I finally got the turbo problem sorted , after changing cat the turbo pipework the lot, it was the n75 valve that was faulty,
    i have a new problem now, ( my wife thinks i have deep pockets ) back to the problem , when breaking i have a thumping noise coming from the front of the car, i have just put new discs and pads on and had a mechanic check the driveshafts for any wear, but couldnt see anything wrong, the noise is starting to get on my wick now, could someone please help ,
    thanks stuart
    audi a4 1.8t quattro sport
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Check the wheel nuts
    Jan 2013
    kilmarnock
    12
    Thanks chris,
    checked the wheel nuts and all fine, noise still there, has anyone got any other ideas ?? abs rings are fine also , the noise is like the abs coming on at low speed, there is no warnings showing, ???????
    Dimokslis's Avatar
    Oct 2011
    Wembley/LTU
    48
    Add Dimokslis on Facebook Add Dimokslis on Google+
    I'd try to check brake pads and calipers also engine and gearbox mounts. It is hard to say anything when have not heard the actual noise.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    What discs do you have fitted standard/drilled&grooved ??
    Jan 2013
    kilmarnock
    12
    Thanks guys,
    I have checked the pads and discs they are all new, the discs are drilled and grooved, all engine and gearbox mounts are ok, when im driving at high speed then braking hard the noise is gone, its just at low speed this happens, hope this helps,
    Aug 2010
    3,138
    Check the grooves of the discs are in the right rotation and also the chamfer of the pad is correct to the rotation other than that id say it was abs related is the noise the same at low speeds when clutched/declutched ??
    Aug 2010
    3,138
    http://www.eclipseracing.co.uk/image...cdirection.jpg
    then the chamfer of the pads should be facing the road due to the trailing caliper setup.
    Jan 2013
    kilmarnock
    12
    Hi thanks for the reply,
    I have checked the discs and pad and all ok, the noise is only at low speed, and its coming through the brake pedal, is also louder when turning when braking , i really cant understand it ???
    Aug 2010
    3,138
    CV joint ???
    Jan 2013
    kilmarnock
    12
    cv joints have just been done a couple of months ago, thanks for tryin bradderz
    Dimokslis's Avatar
    Oct 2011
    Wembley/LTU
    48
    Any of the control arm??
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Can you really feel it through the pedal? Is the pedal banging against your foot? If so, then that's the abs. At slow speeds the ecu can interpret a faulty sensor as wheel slip and kick in the abs. You will only get a abs warning if the sensor fails open or closed circuit if I remember right
    2000 1.8t quattro Sport totally standard (ish)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    ABS activation feels more like a vibration though, the pedal just rapidly pulses, it doesnt "thump"?
    You can get an ABS warning with an iffy sensor, but it depends how it fails. The signal gets stronger/clearer the faster the wheel turns, so a manky sensor/reluctor will often cause the signal to drop out as it appoaches 0mph. At higher speeds, the signal strength improves, and the system works normally. However if the sensor still continues providing incorrect data at speed, the warning light will come on and the ABS will be deactivated.
    TD5 Land Rover Defender build
    Jan 2013
    kilmarnock
    12
    Thanks guys ,
    you really have been a great help, i will change the abs sensors see if that helps, i will keep u all informed cheers again
    stuart.
    Aug 2010
    3,138
    When you remove the abs sensors spin the disc/hub and check each reluctor on the shafts for any cracks or corrosion build up !!
    Jan 2013
    kilmarnock
    12
    Thanks Bradderz,
    i will do i will let you know the outcome cheers again buddy.
    stuart
    Aug 2009
    Stoke on Trent
    114
    I know your pain!! i have the same problem.. its kind of a thumping noise too (hard to describe) and at low speeds only!
    Mine is the Rear Drivers ABS Sensor vcds tells me, but i broke that myself heating the caliper carrier bolts up and still havent replaced it.
    So if all the other things that could be have been replaced or are nearly new then it will definatly be this.
    IIRC i read somewhere trapped air in the ABS Module can create a noise also... maybe try cycling it and bleeding the front brakes
    If i told you i have to kill you, but i could give you a clue and just rough you up a bit!
  1. knocking noise when breaking
    By jetskijimmy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd April 2013, 23:43
  2. Strange Noise when reversing
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 18:40
  3. A4 Strange noise when breaking
    By AudiNick in forum General Technical / How To
    Last Post: 17th April 2007, 20:28
  4. Noise when braking at high speed ?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 15:09
  5. hi pitched squeeling noise when....(97 A4 1.8TQ)
    By ImportRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th November 2003, 21:20
