JMB RetrofitsAH Fabrications
Results 1 to 12 of 12
Thread: AFB fuel pump
    Aug 2012
    37
    AFB fuel pump
    I'm after a replacement fuel pump for my 1999 2.5 V6 TDi Quattro saloon but I'm proper struggling and second hand seems to be the only way but even that is proving difficult.
    What models use the same fuel pump so I can search that. Does it have to be Quattro? Etc etc.
    Thanks!!
    May 2011
    17
    check my car out in the classifieds Classifieds: Audi A4 B5 2.5 tdi 1998 saloon for sale wrexham north wales
    Buy the car then sell all the bits you dont need and make your money back.
    Aug 2012
    37
    Sell me the pump and then sell all the other bits to make your money back
    Anyone know what will and won't fit.
    May 2011
    17
    £400 for the pump, (theres one on ebay for £495) I assume it would fit although mine not quattro
    Aug 2012
    37
    Should of made it clear I'm after the one under the rear seats that sits in the tank.
    Jul 2007
    London
    3,237
    Quote Originally Posted by Looney540 View Post
    Why do you need to change the in tank pump ? it's only there to lift fuel over from both sides of the tank and feed the baffle with fuel so it does not gets dry.
    FOR SALE:
    Aug 2012
    37
    Because the garage diagnosed this as at fault and to be fair the previous owner (my best friend) butchered it when he accidentally put petrol in a few years ago.
    You seem surprised its gone wrong? Not common then? Lol
    Jul 2007
    London
    3,237
    Yes, not common at all. What does it do ? Is the car hard to start or comes up with faults on the diagnostic tests ? They can stop the engine from starting, the fuel shut down switch gets damaged and the car will just turn over without firing. Another issue is that the fuel gauge will indicate wrongly- there's 2 senders in the tank, one on each side and if they don't work in phase then the car will only use half the tank refusing to start even tough there's the other half left in...
    FOR SALE:
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    There is no electrical pump to transfer fuel from one side to the other.
    The return pipe has a sort of suction jet pump in it which is essentially a piece of plastic with a nozzle and a hole, which is used to lift fuel from the "other" bit of the tank and bring it down to the swirl pot.
    TD5 Land Rover Defender build
    Aug 2012
    37
    Well, it started until I had the cambelt changed. Is it possible that when the front end was removed something was triggered that would cut the pump?
    Aug 2012
    37
    Anyone?
    May 2011
    17
    big problem with these cars is that if the fuel lines have been disturbed and the fuel in the lines has drained back to the tank they are very difficult to get the fuel to bleed through.
    if there is air in the clear pipe going into the diesel pump this is the problem, you need to use a hand pump to suck the fuel through after filling the clear pipe with fuel.
    try starting if it wont go spray a small amount of easy start into the intake
  1. best place to buy a late coupe fuel pump
    By lazzaman in forum Classic Audi Forum
    Last Post: 25th November 2006, 21:48
  2. Fuel pump?
    By in forum Classic Audi Forum
    Last Post: 4th April 2005, 19:31
  3. Fuel pump change
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2005, 10:06
  4. Fuel pump problems
    By nunzio42 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 12:09
  5. Fuel Pump Noise
    By europabluea6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th September 2003, 18:15
