EM TuningChris Nott
    Oct 2012
    385
    Detecting camshaft wear on 2.5 v6 tdi
    I guess this applies to B5,B6,C5/Allroad forums,
    Other than popping a cam cover off and having a look with your Mk1 eyeball (not the most ideal situation if you are looking to buy a car on someones driveway!!) how else can you detect cam wear on these engines???
    Ian
    Jul 2007
    London
    3,070
    You can turn the engine and have a peek trough the oil filter hole for cam wear, you will only see one cam lobe but if that's worn the others are not far behind. Put the car in gear and rock it back or forth to turn the engine slowly IF manual gearbox, if auto use the starter.
    FOR SALE:
    Oct 2012
    385
    Thanks for that,
  1. Camshaft wear A4 b5 2.5 TDI AFB '99
    By [BoR] in forum Diesel forum
    Last Post: 18th October 2011, 22:29
  2. How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    By PhilW in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2011, 18:57
  3. High miles 2.0 tdi - wearing not so well ?
    By S2 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th April 2009, 00:10
  4. TDI 170 Tyre Wear!!!
    By coupe-se in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2007, 21:30
  5. 02 Audi A4 TDi 130 - brake wear
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2005, 23:04
