Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    Andyb5's Avatar
    Nov 2012
    62
    Small triangular metal plate on rear door??
    Does anyone know if this plate on the rear door is removable? And how easy it is to remove? Thought id ask before I start pulling the door card off and find out it doesn't come off?? Ones side is bubbling pretty bad and i wanted to remove it sand blast it repaint it
    Apr 2012
    N. Wales, LL22
    1,224
    it will be... but i bet its one of the first things thats fitted to the door
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    TrisLC's Avatar
    Feb 2013
    Cheshire
    333
    Of what I've read I thought this was riveted into place?
    due to that I sanded mind down and wrapped it in some carbon.
    B5 1.8T Quattro
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,346
    you can remove it, but its a bit of an arse to get out.
    Ideally you need to slacken the internal door frame from the outer skin.
    TD5 Land Rover Defender build
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,465
    pita job but doable
    sand down and pain it on the car or wrap.
    Andyb5's Avatar
    Nov 2012
    62
    Cheers sounds like a bit of a mission i was hoping it would come off easy but wasn't optimistic that it would. think ill defo sand it down whilst on the car and i like the sound of wrapping it in some carbon actually will give it a go and post up some pics thanks all
    Sep 2006
    Paisley
    Done this on my 99 A4. Its actually pretty easy. Roll window down,remove the inner plastic trim, and pull down the foam, you will find the securing nut. Once the nut is removed the part can be wiggled out of place.
    Replacements were around£30-35 from Audi.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    i did this on my facelift and yes its fiddly but definately do able, and i didnt have to losen pillar i carbon wrapped mine
  1. Rear Door speakers / Door cards:
    By imported_ZeroK66 in forum In-Car Entertainment
    Last Post: 25th April 2006, 15:07
  2. rear door cards
    By dgannon69 in forum In-Car Entertainment
    Last Post: 13th November 2005, 17:53
  3. Electric windows on rear doors part of option pack
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th November 2005, 09:10
  4. 02 A4 TDi 130 - metal plate clapping noise applying the brakes
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2005, 23:06
  5. Rear Door Speakers in 3 Door (Query for AndyMac)
    By mspah in forum In-Car Entertainment
    Last Post: 3rd January 2005, 12:52
