My sump oil level sensor decided to start to fail - sensor faulty on the dis (the one in the sump) - I changed it for a cheapie from Euro Car Parts, I assume that the level sensor worked however I noticed on its first use that the temp sensor on the dash now does not work while driving and only seems to work when the ignition is on - but the engine not running!
Not knowing how this system works - IS this a known fault with cheapie sensors ? or do I have something else wrong?!
Thanks!
Thanks!
