Sky InsuranceChris Nott
Results 1 to 10 of 10
    nogmeg's Avatar
    Jul 2012
    Raveningham, Norwich
    34
    S4 Headlight washers
    Has anyone here ever failed a MOT because theirs aren't working? Garage said a car with headlight washers needs to have them working, hasn't been an issue before, but anyway....
    Mine Have never worked, andI've never been bothered about it. I've had my bumper off many times and never had to unplug the washers when I remove it, only the fog lights.
    So before assuming it's the motor, pump, hose or that they are jammed etc... Where is the power connector for these washers on a 98' S4.
    Any help much appreciated.
    michaelg1001's Avatar
    Apr 2012
    Sheffield
    110
    As far as I'm aware there is no electrical connector to them, I've had my bumper off for about 6 weeks up until a week ago and the only thing connected to them was the hose from the washer bottle. I presume there must be some kind of secondary pump or solenoid that that kicks in when the headlights are on and the washers come up with the pressure created.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    Yep there should be two pumps, so check you have them, you may need to remove your passenger wheel arch liner to look, if it does it may have been blocked off and disconnected. Check for voltage at this pump, think it should be every 5th squirt with headlights on. No voltage at pump then check the relay under the drivers dash.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Which is the relay for the headlight washers as mine have never worked !!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    The washer jets pop out on pure water pressure, there is nothing electronic about them.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Aug 2010
    3,138
    Quote Originally Posted by ScottB5 View Post
    i no this scott im just curious as to what relay powers it as ive checked the fuses and there all ok so if theres no power to the high pressure pump what supplies it so i can test that. If you take off the supply pipe to the washer jets and throw some compressed air down they will pop out and clear the lines till you cut off the air supply as i tested them when i fitted the S4 bumper.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    So you're just lacking power to the pump?
    Aug 2010
    3,138
    I think so i havent really checked but it may just be the pump but if theres no power id rather no now what it is then try find out whilst im doing the job if you follow !!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    Take the plug off the windscreen pump and plug it in to the head light pump and see what happens?
    nogmeg's Avatar
    Jul 2012
    34
    Thanks guys so I've probably got a bad pump or a bad hose connection.
    I've found this to help sort it.. I just thought there must be some power source.
    AudiWorld Tech Articles
    MOT's are getting stricter now heard they added 20 new things to check for as of April.
  1. How Do Headlight Washers Work?
    By imported_kbininger in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2005, 20:16
  2. Headlight Washer Caps
    Last Post: 13th February 2005, 14:02
  3. Headlight washers!
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2004, 02:20
  4. Headlight Washer Jets
    By greski in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2004, 13:23
  5. Headlight washers
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd March 2004, 01:24
