EM TuningChris Nott
Page 3 of 3 FirstFirst 123
Results 81 to 110 of 110
Like Tree4Likes
Thread: tqs clutch inpectiuon/options
  1. #81
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    Either of your flywheels would work, but they seem a bit pricey to me. I wouldnt want to pay much more than 30-40quid delivered. They're not much more than £100 new afaik, so no point paying ~£70 for a used one?
    TD5 Land Rover Defender build
  3. #82
    boost-addict's Avatar
    Aug 2011
    977
    ok so a abk flywheel works? thought it was only 1z flywheels, wish i had enough knowledge to search for this stuff!
    are audi s2 flywheels the same as the 1z flywheel im looking for? as you said you asked for a fly wheel on the s2 forums, and ive found a s2 1z flywheel
    you say there easy to find but im struggling
  4. #83
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    The S2 flywheel has 8 bolts instead of 6 to bolt to the crank iirc ??
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
  5. #84
    "Stick a V8 in it!"
    14,907
    hold up.
    S2 flywheel is no use.
    The flywheel needs to come from a 4 cylinder car. Its fitted to most 4 cylinder engines used in Audi 80/100/Coupes etc. The 1Z is a 1.9TDI, but its also fitted to 1.6/1.8 and 2.0 petrols from a similar vintage.
    I posted on the S2 forum because many folks on there happen to have the older model audis that come with the right flywheel.
  6. #85
    Aug 2011
    977
    ah right ok, got the wrong end of the stick, ok so audi 80 1.6,1.8 and 2.0 and the 1.9tdi has the correct flywheel and i want 6 bolt holes for starters,
    im just following lol been a great help so far!
  7. #86
    Aug 2011
    977
    ok heres what ive found so far
    Flywheel part number 02605269LX fits the following engine codes: ABK, AHL, 1Z, AHU, AFF, ADP, ACE, AAE, ADW, JW, AAD, PS, NP, 4B, SH, RN, JV, PP, NE, JN, DZ, SD, RU, PM, RNA, 3A, JK, RA, SB, 1Y, 6A. ABT, ABM, ABB, ADA,AAZ
    so would a fly wheel from a abk engined audi a6 year 1996 to 1997 2.0 work?
  8. #87
    "Stick a V8 in it!"
    14,907
    yup
    (proper part number is 026105269L though, you were missing a 1)
  9. #88
    Aug 2011
    977
    so if this flywheel is from a audi a6 with a abk enigine then it should work. its not bad price either, £38 posted
  10. #89
    "Stick a V8 in it!"
    14,907
    buy it already :P
  11. #90
    Aug 2011
    977
    just have!!!!
    ok now im happy, thanks for the help.
    so clutch plate, i think this is right but im not sure, if it is ill buy two!!!
    AUDI A4,A6 ,PASSAT V6 CLUTCH DISC PLATE LUK 324021910 | eBay
    or the one you linked
    GENUINE AUDI A6 C6 3.2 2.8 V6 BDX AUK CCDA FWD 240MM CLUTCH PLATE 06E 141 031 AX | eBay
    then as for the pressure plate, i thought i found one and put it in my ebay watched items but i must have not done so
    so ata and agk lt van and also audi s2 pressure plate, any other engines or is that it
  12. #91
    Aug 2011
    977
  13. #92
    Aug 2010
    2,873
    Quote Originally Posted by boost-addict View Post
    this wont work as i dont think its flat i think the fixing points are raised on that engine code you can only used an ata/agk one !!
    oh if you get a liked its my big thumbs on this tiny iphone screen lol
    boost-addict likes this.
  14. #93
    Aug 2011
    977
    ah dam i misread it. swear it said agk, been looking at the screen too long!
    ok so i can only find two
    Clutch Kit VW LT 97-06 | eBay
    3pc Clutch Kit for Volkswagen LT 2.8TD 09/97 - HK7561 | eBay
    can some one tell me which one of the clutch plates to go for.
  15. #94
    "Stick a V8 in it!"
    14,907
    First one has a solid centre, so no use, you need the sprung hub like the second one.
  16. #95
    Aug 2011
    977
    yer again missed that, just been round and round searching a s2 clutch or a lt van clutch.
    only ones i can find are the gsf one or the borg and beck one,
    can you order just the presure plate from gsf, sure i read that some were.
    then all i need is the thrust bearing. and seals
  17. #96
    "Stick a V8 in it!"
    14,907
    Try jason at all german for the cover, Sachs 3082 919 001
    He supplied my last ones.
  18. #97
    Aug 2011
    977
    cheers, what was the price? and he has the rear crank seal
    thought i may as well stick this info here
    VW part numbers:-
    Pressure Plate 035 141 118 X = Sachs 3082 919 001
    Friction Plate 034 141 032 M = Sachs 1862 625 001
  19. #98
    Aug 2011
    977
    great so been on phone to jason this morning, still waiting for a a call back
    aragorn what was the rough price for a pressure plate and seals and thrust bearing.
    also bought and paid for 2 of the main parts
    Audi A6 Flywheel & Clutch 1994-1997 2.0 ABK | eBay
    now ive been looking at the audi a6 flywheel/clutch there and it almost looks like its already a 240mm clutch cover.
    maybe im wrong
  20. #99
    "Stick a V8 in it!"
    14,907
    The proper 240mm cover hangs off the edge of the flywheel, so its not a 240mm one in the pic.
    Thrust bearing i got from ebay fro about a tenner or so, genuine audi one.
    Pressure plate was around £100 iirc. They're £115 from the dealer, so should be a bit less than this.
  21. #100
    Aug 2011
    977
    right ok. so what am i getting from jason, pressure plate and seals?
  22. #101
    "Stick a V8 in it!"
    14,907
    might as well get the bearing from him too if you can
  23. #102
    Aug 2011
    977
    yep ordered the pressure plate but had to pay out for tyres, so im going to order the thrust/release bearing, and rear crank seal, next month unfortantly he dosnt have the gear box input seal, so ill get that from vw/audi
    so good news and bad news,
    good news is jason has ordered the pressure plate, bad news theres a 4-6 week lead time!!!
    so any way recived the flywheel this morning, that was great only paid for it mid afternoon yesterday!!!
    and as you know paid for the pressure plate
    so heres some pics, and thinking is it worth chucking the pressure plate and disc back on, the pressure plate is in good nick, and the clutch has about 1/3 life left. might be worth at least the pressure plate bought with a new disc?
    any way
    so just waiting on finding out were i can get my flywheel sorted
  24. #103
    "Stick a V8 in it!"
    14,907
    Flywheel looks great.
  25. #104
    Aug 2011
    977
    cheers, cant believe theres a 4-6 week wait on the pressure plate, but that suits me coz im all paid out till next month.
    should i stick the pressure plate back on ebay? or just throw it? didnt know if it was worth something to some one
    any way. i did say this in a pm but aragorn and bradderz thanks ever so much for the help. always been great but you have helped me out more then before so appreciate that,
    so any way called few companys, first one umed and ared about how a 10mm bolt hole wouldn't be deep enough, i explained how the bolt is only 10mm any way. (there or there abouts) and its been done before, then started asking if it was cast iorn or steel. i have no idea lol so
    2nd comapny nearly had a heart attack when i explained what i wanted and pretty much asked why i was doing it, i explained and he understood but couldnt fathom why one would do such a thing lol
    and then called modus engineering and explained the flywheel was from a audi 80, pressure plate from a vw van and i needed one to fit the other, i explained it had been done before and offered to send pics of said work i told them needed i needed 9 holes drilled, 6 of those blind tapped to accept a m8x16 bolt, and he knew exactly what i wanted and understood why and what to do
    he sounded dead certain and experienced and said with the resurface would take hour to hour and half, they charge £50 an hour so should cost about £75 but i suppose budget for £100.
    so if any one is following the same path, because some one has also ordered a pressure plate from jason then if your close to tunbridge wells then there the people to call. give me a pm and ill send over the details
    so this thread will go dead for the next few weeks as theres no alot to update till i get my pressure plate, have finally ordered some 6k hids, and may also get some matt vinyal to cover my roof. not 100% there but were see.
    any way till theres some action not much i can do!!!!
  26. #105
    Aug 2011
    977
    well still no movement. got an email back syaying it should be with jason tomorrow,
    so hopefully i cant get that and get it to a machine shop.
    but im struggling with ever more my clutch slip, the thrust bearing rattles and even finding it hard to select gears
  27. #106
    Aug 2011
    977
    well just got a email. and the pressure plate has arrived!!!!!
  28. #107
    Aug 2011
    977
    and apprently payment wasnt taken, any ho,paying for this wednesday, can you guys tell me of this was defently the correct pressure plate.
    also is there any harm in getting the pressure plate holes drilled and tapped by me? would cost me over £50 less.
  29. #108
    Aug 2010
    2,873
    Id get it done at an engineers so its 100%, if you get it a tad out it may cause judder/balancing issues !!
    jbh likes this.
  30. #109
    Aug 2011
    977
    yer true, got it sent off to modus engineering in twells,
    ok so for part numbers i want to confirm some part number
    clutch release bearing
    01e141165b
    rear crank seal
    028103171b
    gear box seal
    i have two hear, esc list both as input shaft seals for my car, 012311113b or 016311113b
    not sure which one is the one i need
  31. #110
    Aug 2011
    977
    Going to order these last bits up. Can some one confirm or advise me on the part numbers for
    Thrust/release bearing
    Rear crank seal
    Gearbox input seal
    And if poosible
    Flywheel to crank bolts
    Clutch to flywheel bolts
  1. Replies: 14
    Last Post: 1st March 2013, 22:55
  2. Clutch/Flywheel options for BAM motor
    By aragorn in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2011, 12:35
  3. A3 tqs clutch help
    By bansheeboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2010, 20:41
  4. Audi A4 B5 TQS clutch change
    By steveboyo in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2009, 21:22
  5. 1.8 tqs clutch options?
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th February 2009, 18:29
