EM TuningSky Insurance
Results 1 to 9 of 9
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    1997-98 A4 TDI with cruise control wiring diagram wanted please!!!!!
    After an aborted attempt at fitting cruise control to my late 1998 A4 today it turns out that what should have been a simple plug & play exercise has ground to a halt.
    I really need a wiring diagram for the cruise control circuit for a car 1997/98 please, Haynes doesn't cover it at all and the Elsawin program on my PC has decided it doesn't want to show diagrams anymore!
    I have the Facelift wiring diagram (dated 2.99) and its incorrect for my car.
    The big issue is that I dont have a 15 pin white connector under the plenum chamber /ECU (which my cruise control stalk wires should have fitted into to) but a smaller 10 pin one instead....
    Until I can at least see how the CC stalk is meant to be wired in on these earlier cars I fear I'm wasting my time trying to go any further.
    I'd be more than grateful if anyone could post up the diagram or a link to one (have Googled but got no-where!)...
    Thanks in advance......
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    B5 Passat TDI - Retrofitting Cruise Control
    Is this of any use? It shows that plug and where to connect the pins?
    2000 1.8t quattro Sport totally standard (ish)
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Quote Originally Posted by NineNails View Post
    Many thanks, but I've had a printed-off copy of that thread in my hands all afternoon and I'm still none the wiser!
    The trouble is my Kufatec loom has just PIN numbers on it (its designed to mate up with that 15 pin white connector after all) , I need the correct wiring diagram to try and figure out which colour plug each wire should go to.
    The fact that the 4 wires go to 3 different connectors is tantalising , am sure it won't be too difficult to do, if only I had a correct wiring diagram!!!!!
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,644
    If your still stuck when im home I can send you the diagram from ElsaWIN.
    Currently rolling in a SKODA!!!
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Quote Originally Posted by Arrkon View Post
    That would be brilliant, thanks!
    I need the cruise control current flow diagram for an AFN 110bhp TDI, apparently the ECU changed from a 68pin to an 80pin one sometime in '98 , so need the 80 pin diagram......
    Thanks again.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    you have an 80pin ECU with the early harness?!
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    Any one of a pic of the 80 pin ECU and 68 pin ECU?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    It looks that way!
    2 separate connectors on the back of the ECU, one is larger with 52 pins, the other smaller with 28, so that makes it an 80 pin right?
    Dont understand this mixture of old/new that appears on my car, was it made on a Friday afternoon perhaps?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    Quote Originally Posted by Nessy View Post
    It looks that way!
    Friday afternoon special.
    Shame it never works in our favours.
  1. Tail-chasing with Cruise Control retrofit
    By heeman10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th May 2010, 10:40
  2. Cruise control wiring
    By 8ig_steve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2010, 11:23
  3. Cruise control wiring loom
    By adamss24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th July 2009, 14:42
  4. C5 Indicator stalk with Cruise control
    By simonwjones in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th July 2007, 16:15
  5. Calling people with cruise control!!!! Please help
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th September 2004, 01:29
