Sky InsuranceAH Fabrications
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By ScottD3
Thread: New sump,anything else?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    To aid me with one project and stop an oil leak I'm going to replace my sump for a facelift unit with oil sensor hole, while it is off I'm thinking it would be good to replace the pick up pipe.
    I understand its a sub frame drop, with all this off, is there any thing else that's worth looking to replacing?
    On the list I'm thinking of sump bolts, sump gasket, cam cover gasket, cam cover bolts.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    If its the same as the 1.8T, you cant buy the pickup on its own, only the whole oil pump.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Not a clue.
    Not even sure what's needed to replace the pump.
    One of the reasons for this post.
    Does anyone know?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I think they are the same as the 1.8T iirc !!
    Jan 2013
    59
    Im not sure what engine you have in your one but when i dropped the sump on my 1.8T I replaced the following..
    Engine oil
    Coolant
    Sump Plug
    Oil Pump (complete)
    Sump sealer
    Oil Filter
    As mentioned you might not need all this if you have a different engine.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    oo yeah, I forget some of the newer members don't know my car lol.
    Its a 1.9TDI AFN engine.
    I'm planning on doing it in time for the next oil service. hopefully the weather will be better and it will give me time to get the parts up together.
    Will the coolant be touched?
    Does anybody bother replacing bolts when taking the sump out?
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    don't think the coolant will be touched.
    can't see why you can reuse the sump bolts,maybe use some threadlock though.
    would it be easier to lift the engine a bit to get the sump off,rather than drop the subframe?
    tony
    Jan 2013
    59
    Sorry you may not need the coolant, i changed the thermostat when i was there so needed coolant.
    Thanks J
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Quote Originally Posted by tonya4 View Post
    tony
    Not a clue mate.
    This is going into realms i've not touched or seen.
    I've got help so its ok.
    I don't mind reusing bolts/nuts but it just seems right to use new bits lol
    might be able to lift the engine but it would be easier to do it with out the sub frame, give your self some room.
    I got a magnetic sump plug with a bulk load of washers, I just use that all the time and keep an eye on the metal build up.
    Been very little at the moment.
    Tom_B likes this.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Where are you sourcing the sump Scott?
    I need to replace mine as its been cracked since I bought the car nearly 3 years ago.
    Wanted to get a genuine one - but the 240€ price scared me
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Quote Originally Posted by B5 BIKER View Post
    Audi depending on price.
    I did get a quote for one before, I cant remember the exact number but I don't think it was that much or any where near.
    I'll let you know the price when I get a quote.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Quote Originally Posted by ScottB5 View Post
    cheers,
    you say you were planning to change for a facelift version with hole for sensor?
    mine is a 1.9tdi afn facelift - no oil sensor though.
    even when it has ran low in the past, there is no warning light for low oil!!!
    "Stick a V8 in it!"
    15,390
    1999 facelifts with analog clock dont have oil level sensor.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Full digital clocks have the oil sensor.
    That as well as oil leaks are kind of making me do this.
    I need to get my rev counter working then its 100% FL clocks in a PFL car.
    I hope. lol
  1. Anyone fitted a 2.7T lump into anything else?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2007, 21:41
  2. Considering a new S3 anything i should be careful of ?
    By Gareth Hill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th May 2007, 15:40
  3. maf/temp sender anything else??
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2007, 17:38
  4. Coolant and Haldex servicing and anything else ?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2006, 13:08
  5. car getting lowerered tomorrow anything else worth doing?
    By pablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2006, 09:26
