Badger5EM Tuning
    Mar 2013
    24
    fitted second hand abs module, VCDS cant find it, why?
    Like the tittle says, I fitted an untested abs module, the bosch number is the same, but the VCDS says it cant find the module ( No response) when i search it,
    Need help, as to why, does it need coding, i was told it wouldn't.
    May 2012
    RETFORD, NOTTS
    1,748
    Are you using genuine VCDS? If so, check fuses and connection, still no response probably a foobar module. This error is what prompted me to change mine on the A6.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Mar 2013
    N/E Scotland
    7
    Check the 12vdc and earth at the module itself, Then check the wire form the plug at the module and your 16pin dlc, I think it is purple but not sure! if they are all good, you have bought a u/s module. If the part number is the same it should not need recoded! good luck!
    Jul 2007
    London
    3,213
    Clue is in the title: untested, which in laymans terms means fooked !
    FOR SALE:
    Mar 2013
    24
    Yeah I got it off a tqs which was breaking, I never asked if it worked, because it was pretty irrelevant, it would be soon to break if it was working, so I bought it at a price where a repair is stomachable,
    I was just worried if the not recognising was indicative of it needing coding or something stupid, but it should be fine when repaired then .
    Mar 2013
    N/E Scotland
    7
    Yes should be.
  1. Replies: 11
    Last Post: 9th September 2011, 23:16
  2. Replies: 9
    Last Post: 8th September 2011, 23:42
  3. ABS module won't code with VCDS???
    By BILKO1 in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th February 2011, 07:01
  4. Buying A3 1.8 T sport second hand
    By fnbloke in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2004, 00:14
  5. second hand prices
    By richy in forum Volkswagen and other VAG
    Last Post: 20th July 2004, 16:53
