Monster MotorsportChris Nott
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Pre fitting woes ??
    Im going to be installing my s4 sideskirts tomorrow i was jus wandering if you HAVE to use the S4 brackets that hold the skirts in place that are in front of the rear wheels or can you use the exsiting a4 ones ???
    also any tips/advice on how you did yours either OEM or DIY tips as i only have the skirts and super velcro !!
    thanks in advance
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    The a4 doesnt have brackets in front to the rear wheels. The plastics are all different, too, like the little bits that clip into the ends of the door trims. Mine are secureds with s4 brackets at the back and a bunck of sikaflex with a few rivets for good measure
    Aug 2010
    2,866
    So i will need the S4 brackets then ??? Mine looks as though it has the little mud guard thing on the car ???
    Apr 2004
    12,354
    Quote Originally Posted by Bradderz_1988 View Post
    mud guard thing needs to come off mate
  1. Fit cupholders to pre facelift without any Mods!!!
    By andrewjones in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2013, 16:13
  2. A3 1.8t AGU Downpipe Fitting Woes
    By WorkInProgress in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2013, 18:10
  3. Ko3s fitting at tip fitting woes
    By Turboman-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2011, 09:55
  4. Fitting FK Coliver on A3 Woes
    By elucidate in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2006, 11:18
  5. Fitting facelift A3/S3 headlights to a pre facelift 1998 A3
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2005, 20:10
