Chris NottSky Insurance
    Mar 2013
    Belfast
    23
    Key doesn't unlock all doors or deactivate the alarm
    Went to open the car today with the fob and it wouldn't open. My main problem though is with the key, it was just unlocking the drivers door and not the rest or not deactivating the alarm so when i opened the door the alarm was going off. Eventually after a good few tries it opened all doors and the central locking worked... but once only, very temperamental.
    Any ideas as to why its doing this?
    As the fob was working i believ the pump is ok (non sunroof model too) going to try and resync the fob later on. But as a back up it would be nice to be able to manually open the doors with the key.
    Could there be a dodgey switch or something within the drivers door? Are the door panels/cards easy to remove?
    Cheers for the help
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    If its a facelift, i think its intentional.
    If you open the car with the key, the alarm goes off, and only shuts off when you turn the ignition on.
    If its PFL, then the sensor in the door that detects the key being turned is likely broken, my brothers old S4 was like that, and he had to use the passenger door to unlock the car when his fob battery died.
    TD5 Land Rover Defender build
    Mar 2013
    Belfast
    23
    Passenger one is the same, thankfully got my fob communicating with the car again but if it ever dies ill be in trouble. Can you just change the door latch inside the door to fix this issue? My interior light wont come on with drivers door either so guessing its all in this latch set up?
    cheers
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    614
    Quote Originally Posted by billybaggins View Post
    cheers
    Reminds me of a similar intermittent issue my stepfather had with his (dog) of an A6 Avant a few years ago....sometimes he'd unlock the car with the remote and get in but the the interior lights wouldn't come on and the alarm would go off!..
    We traced it to a damaged/dodgy microswitch within the drivers side door lock itself; the fob was physically unlocking the car but the microswitch was not causing the alarm to be deactivated etc, hence all the noise when opening the door....
    A new door lock cured it (which meant the interior panel and inner 'frame' of door had to come out!); I believe the A4 has the same design of lock?
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    Mar 2013
    Belfast
    23
    Yeah i'd say it's the same. I thought maybe if the door panel was removed the lock could just screw out and a new one put in but using the same barrel so you dont need to change the key??
  1. Central locking locks all won't unlock drivers door.
    By R.Ten in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2013, 20:34
  2. [Return] key doesn't work when posting on ASN
    By Alex C in forum Forum Support
    Last Post: 16th February 2013, 23:41
  3. Open all doors at once
    By m.a.r.k in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th September 2011, 08:23
  4. A6 Allroad Ignition Key - doesn't switch off systems when pulled out
    By deskboy231 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd March 2010, 09:49
  5. unlocking drivers door in the cold
    By dans3.0 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd February 2009, 21:23
