EM TuningMonster Motorsport
    Mar 2013
    Belfast
    23
    Power stering 'kicks back' low speeds or stationary
    This is a strange problem with my steering. First noticed it going round a round-about at constant speed with steering wheel in same position and i felt the wheel get light then heavy then light again etc...
    Then parking at work this morning i had to wait for someone to park on front of me and i held the steering to the left in about the 10 o'clock position and the only way i can describe it is as kicking back in your hand. If while holding it at 10 oclock angle and i move it the the left even a few mm its light then goes heavy and kicks back at me as though trying to straighten up again.
    Any ideas?
    Its a 1998 avant tdi. I have checked the controls arms etc and theres a slight bit of play in my right upper arms but its minimal and causes no clunks or knocks. I know this can cause a wobbly loose steering feeling but can't see how it would make the ps kick, so must be another issue.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    check the fluid level?
    TD5 Land Rover Defender build
    Mar 2013
    Belfast
    23
    Suppose that's a good start.... ill check after work and post back. I was thinking something serious before checking the small things. Thanks man
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Belt could be slipping?
    2000 1.8t quattro Sport totally standard (ish)
    Mar 2013
    Belfast
    23
    It's not the fluid anyway its dead on the max mark. Any ideas how i can check the belt etc or is it a job for the mechanic? cheers
  1. ABS keeps kicking in at low speeds? Only since CV boot change tho?
    By Charlies604 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2006, 13:12
  2. Noise when turning steering wheel at low speed
    By Boyakasha in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th October 2005, 13:27
  3. Wierd juddering at very low speed/revs
    By imported_shkwav in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 21:32
  4. Powerflex dog bone mount and low speed Judder?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2005, 15:59
  5. Very low speed behaviour of DSG
    By A4_2point4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2005, 08:52
